What are the average stock EVO 5-60mph times?
Old Nov 13, 2003 | 01:03 PM
GottaGoFaster's Avatar
Was wondering if anyone knew the average time a STOCK Evo goes from 5-60mph. I want to compare my results...I assume you would be in the 1500-2000RPM range in 1st gear??
I want to time mine with a stopwatch, not the most accurate but cheap nonetheless
I posted this in Drag Racing...but I don't think it belongs there so I posted it here. I can't delete the post or else I would have.
Old Nov 13, 2003 | 01:07 PM
boostedwrx's Avatar
slow
Old Nov 13, 2003 | 01:23 PM
revhappy's Avatar
around 6.7 seconds.
Old Nov 13, 2003 | 01:35 PM
inariv5573's Avatar
The time should be quicker than the 0-60 time. You are starting from 5 mph rather than zero. This is provided you are in first gear though where you will be launching with some spin on the engine. If you are in second however then it will be slower because you will be inder the sweet spot. I know because when I am cruising around parking lots in first gear and just give it a little gas the car leaps harder than when I am just coming off idle.
Old Nov 13, 2003 | 01:45 PM
You're saying the rolling 5-60mph time should be FASTER than a 0-60mph time with a 6k launch?
Old Nov 13, 2003 | 01:49 PM
Evo11V's Avatar
Veteran: Army
Definatly not!!!! at 5mph you are below your boost, meaning you have a crap load of boost lag!
Old Nov 13, 2003 | 01:51 PM
chrismr's Avatar
i dont think that a 5-60 would be faster than 0-60 because of the fact that when you are going 0-60, you are normally dropping from around 5.5k rpm.. and your turbo is at full spin.. where as when you go from 5-60 you have that little tad bit of turbo lag, unless you rev it up and dump the clutch.. just my 2 cents..
Chris
Old Nov 13, 2003 | 01:58 PM
boostedwrx's Avatar
EVO is a pig from 5mph. It ONLY gets these fast *** 0-60 MPH and 0-60 FEET is due to the AWD launch. Look at Buschurs EVO running 0-60 MPH (Yes Miles per HOUR!) in 2.9 seconds... I bet if he took off from 5mph that figure would be up to 4 or even 5 with their power.
Old Nov 13, 2003 | 03:10 PM
alex_alex's Avatar
God, this has to be the worst reasoning i have come across in a long time.
But to cut to the chase, you're wrong.
Old Nov 13, 2003 | 03:16 PM
MYEVOVIII's Avatar
I'm sorry but I have to agree with alex alex
Old Nov 13, 2003 | 04:05 PM
I did a "trial" run with a stopwatch and got 5.25secs from 5-60 on my EVO
Old Nov 13, 2003 | 04:12 PM
TRDHarrier's Avatar
5-60, well, at 5 mph, u can drop ur clutch rev to 6K and drop it back in...that'll be fast and also fast on ur drivetrain and clutch.
Old Nov 13, 2003 | 04:15 PM
mikec's Avatar
You've got a mighty fast Evo there! I'm lucky to get that kind of number with a pretty strong 0-60 launch.
Old Nov 13, 2003 | 04:27 PM
SuPaNooK's Avatar
hmmmmm not bad....
Old Nov 13, 2003 | 04:41 PM
There might be some driver error due to my clicking abilities of the stopwatch. I will try some more to verify. I am modded too
