Ebay short shifter
Old Jun 14, 2010 | 05:18 PM
Blast83's Avatar
Ebay short shifter
Does anyone know how much shorter the ebay short shifters are? I'm looking to buy a new shift boot since I remember my last car rubbing a lot of burning a hole though the boot. The place I'm going through for a new shift boot will shorten the extra for me but I'd like a somewhat exact measure, if possible, so I can order them at the same time.
Old Jun 14, 2010 | 06:36 PM
2d-ink's Avatar
I have one its not even that shorter then stock.. almost the same height.. just put the shift cable at a different location.
Old Jun 14, 2010 | 06:37 PM
2d-ink's Avatar
maybe like half an inch... forgot to mention that
Old Jun 14, 2010 | 06:59 PM
BIGJEFF's Avatar
save your money and buy a name brand you'll be better off down the road
Old Jun 15, 2010 | 06:24 AM
syclone50's Avatar
I had one on my last evo and it seemed to be just as good as the other more expensive ones. Shifts felt nice
Old Jun 15, 2010 | 06:26 AM
Bggstin's Avatar
This is sad.
...How about you keep the damn shifter stock and buy a shep trans, metal bushings and a tilton twin disc - gauranteed better shifts.
Old Jun 15, 2010 | 07:04 AM
gsrboi80's Avatar
They are exactly the same as any of the name brands. In fact most of the EBAY ones come with the plastic caps and shifter base bushings.
Search around before you just rattle something off because more people on here run the EBAY short shifters then any other
Old Jun 15, 2010 | 07:44 AM
SoloEvo's Avatar
had my "ebay" short shifter for 20,000 miles now. never given me any problems and i see no reason to pay X amount of dollars more for a name in this case.
Old Jun 15, 2010 | 08:12 AM
ExplosEvo's Avatar
Originally Posted by Bggstin
This is sad.
Hmm...$5k+ Vs $40. Thats a toughy!
Old Jun 15, 2010 | 06:07 PM
BIGJEFF's Avatar
You learn something new every day thanks for the info didn't mean to push your button.
Old Jun 15, 2010 | 06:09 PM
GG_9_SE's Avatar
Ebay short shifter FTMFW son!
I suggest you people to check out the https://www.evolutionm.net/forums/ev...-100-time.html thread and follow all the instructions, and make sure you dremal out some of the shifter counsel so you will be able to set the shifter at its lowest setting.
Old Jun 15, 2010 | 06:19 PM
wizechef's Avatar
true! i have the ebay one as well and i believe it has 2 diff settings.. one for "15%" shorter and one for "40%" shorter... if you go with the 40% i believe you need to dremel it out...
Old Jun 15, 2010 | 06:32 PM
Blast83's Avatar
This is sad.
How that will give me a shorter shift is beyond me. Sig states I have shep transmission already. I had a short shifter in previous cars and like the closeness of the gears.
Anyway,
Question still stands: How much shorts than stock are these (in inches)?
Old Jun 15, 2010 | 06:42 PM
GG_9_SE's Avatar
it honestly doesnt rub on the shift boot. so i wouldnt worry about it. save your money for other things. mine isnt even really crinkled up at all.
Old Jun 16, 2010 | 01:54 PM
syclone50's Avatar
my ebay shifter was probably 1 to1.5 inches shorter than stock
