transmission removal
Old Jul 8, 2010 | 05:42 PM
domantas's Avatar
ok its second time i have pulled my motor out and my clutch gave up on me. I have new exedy kit waiting to be put in.
I know it would be easier just to take the whole motor out together with a tranny, but I have no acess to a cherrypicker right now. So you guys just lower the engine a bit with a jack to make some clearance for tranny to slide out? What do you use to support the tranny and lower it down? Tranny jack? I think I can get it out with the help of my brother and help of my second car jack, but that thng is too damn heavy to lift by hand and put it back in... Any input would be apreciated, I wanna save $600 and do it my self
Old Jul 8, 2010 | 05:46 PM
vanilla2's Avatar
Have you checked the how to section
Old Jul 8, 2010 | 06:08 PM
JakeTheVIII's Avatar
I wouldnt pull the engine just for a clutch anyways that's a lot more work. You need extra hands and it's not that heavy. take out the tranny motor mount and the front motor mount so you get a better angle, pop the throw out bearing loose, unbolt, pull off. Use a regular floor jack with some padding on it to help ease it down. You'll need help getting it back in.
Old Jul 8, 2010 | 06:30 PM
evo-kro's Avatar
all u need is a strong friend and some jack stands. then a couple jacks ive donr it many times its not easy but its do able. it also helps if you drain the tranny fluid.
Old Jul 8, 2010 | 08:11 PM
chaotichoax's Avatar
how to section
closed...
MitsuJoe
468
Feb 20, 2016 11:17 AM
theLAM
Mar 27, 2010 08:14 AM
justa4banger
13
Sep 28, 2009 09:36 AM
strongbear0
10
Apr 10, 2005 07:17 PM
MitsuJoe
Aug 1, 2004 01:59 PM
