wheres the 35r crowd at?
Just got my precision gt35r on my car recently, its deffinantly a highway turbo, it pulls pretty nuts! made 417/330 on 93 octane, whats the rest of the 35 cars making? heard its good up to around 650 horse
you can make upwards of 500whp at 28-30psi on 93 octane pumpgas w/ a standard garrett 3582r. Turn up the boost, lol.
450whp easily on about 25psi...
and if you have a built motor that flows better w/ an increase in compression, you can break 500whp at even lower boost levels. (eg. 25-26psi)
and yes 650-700whp is doable ranging from standard 61mm to billet 62mm versions on 35-45psi boost using high octane fuel.
I made 500/432 on Pump gas @ 29 psi ....Keep in mind this is on stock heads,Stock intake manifold/T.B and old school HKS cams ... Everything else is Built -
With S2's,AMS F1 and boomba T.B it will be around 550-580 awhp..: )
my fuel pump maxed out for some reason, so he said he kind of had to back off
but I do have every possible supporting mod not including head and block
417 on a mustang dyno boys, this car is very nicely set up. It is on a stock motor with supporting mods. Once we get the lean issue worked out im sure we can aim for more.
-Cisco
-Cisco
