Cleaning inside of Intercooler?
Old Jul 30, 2010 | 12:56 PM
Maniac978's Avatar
Took apart my pipes the other day and inside of my IC looks nasty. I assume this cant be a good thing. it's like some nasty gunk in there. just wondering is that safe? should i get rid of that somehow? if so how? what do i use? I have boost leak issues and all kinds of nonsense.. dats why im asking. please help.
Old Jul 30, 2010 | 01:13 PM
Svendiesel's Avatar
Apparently the best way to clean an intercooler is with acetone. There was another thread on this just the other day.
Old Jul 30, 2010 | 01:58 PM
4G63Rules's Avatar
Gasoline works wonders as well. You will have to do several rinses to get the best results.
Old Jul 30, 2010 | 02:01 PM
turbolagdsm's Avatar
Compressed air and some cleaner...
Old Jul 30, 2010 | 02:14 PM
OneCrzyEvo21's Avatar
Gasoline does work really well..
Old Jul 30, 2010 | 02:50 PM
Maniac978's Avatar
Wow!!! Gasoline? Acetone? That sounds like something I shouldnt do on my own because I dont know what im doing. I wish it was a video or something.. I'm do some more research. Thanks for the help guyz.
Old Jul 30, 2010 | 02:54 PM
Psquared's Avatar
Well, if it's grease, that stuff will cut it. I'm thinking the safest is a parts cleaner, or steam but I'm not sure how you would do either in your garage. You definitely want to clean that out though. You can thank that nasty film to the crank blow buy hose that's plumbed into your intake pipe.
Old Jul 30, 2010 | 02:55 PM
bluebanana23's Avatar
I used dishwashing liquid. Just rinse it out until no more suds come out. Air dry for a whole 24 hours or stick hair dryer to one end tank. Viola, clean fmic.
Old Jul 30, 2010 | 03:02 PM
evo8426's Avatar
i would cap off one end of the intercooler with a coupler and pvc cap like from a boost leak tester and fill it with whatever cleaning solution you decide on and then cap the other end and then shake it vigorously until clean
Old Jul 30, 2010 | 05:33 PM
xmaciek82x's Avatar
After you clean your IC, I think it's time for a catch can.
Old Jul 30, 2010 | 05:35 PM
turbotalawd's Avatar
Using gasoline is the best way imho. Ive done it several times and if your careful and obviously not have any flames around and do it in a well ventilated area, you should have no problem.
Pour some gasoline in one end, cap both ends or put your hands around the holes, and swish around. Pour it out, and keep doing that until the gasoline comes out clear.
Old Jul 31, 2010 | 12:11 AM
crazy_ugly_coyo's Avatar
+1 on gasoline and getting a catch can to keep the issue from happening again
Old Jul 31, 2010 | 04:51 AM
4RETECH's Avatar
Yes there was,LOL
https://www.evolutionm.net/forums/ev...tercooler.html
Old Jul 31, 2010 | 06:02 AM
Roberti22's Avatar
i did this for my DSM back in the day...Gasoline is the the way to go just be safe about it
Old Jul 31, 2010 | 10:30 AM
4g63Moon's Avatar
Which octain does the best? premium? or does it now matter lol I'm going to clean mine out also
