difficulty starting
Old Aug 3, 2010 | 11:24 AM
barneyb's Avatar
Originally Posted by Skylineracer
which connectors should i clean? literately with a wire brush clean the connections hooked up to the starter and the battery terminals? i checked on my turbo timer today and the battery voltage says 12.6 which sounds right for a dry cell battery. I know this isn't a measure of amps but it sounds ok to me.
Yeah, the cable between the starter and the battery. Also, make sure you have a good ground to the block and those connections are clean.
You can have great voltage readings but that does not mean the connections will carry current - not in the amount the starter requires anyway.
BTW, my experience is that the battery voltage can drop as low as 9 volts when the battery is cranking the engine.
Old Aug 3, 2010 | 11:35 AM
06RedRalli's Avatar
Agreed check all your cables and make sure they're tight...probably just a loose wire somewhere...or bad ground...this happened to me and that solved it was a bad ground
Old Aug 3, 2010 | 02:52 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
lol looks like i have a project
Old Aug 31, 2010 | 09:32 AM
dancarroll0283's Avatar
Im having this exact same problem right now!!!
Old Aug 31, 2010 | 11:16 AM
eyewhen's Avatar
Could just be a dying battery, they dont last forever. Is it a mini?
wazzelby
Mar 29, 2017 06:28 AM
FlashEvolution
Jun 22, 2016 08:00 AM
AutoXMRIX
Mar 9, 2016 07:02 AM
hooliganSKATE
Dec 24, 2015 01:57 PM
Night12000
Sep 28, 2015 08:03 AM
