backfire question
Old Aug 12, 2010 | 01:08 AM
anton406's Avatar
backfire question
so i was driving down when i hit the throttle hard then shifted from 2nd to 3rd i heard a popping sound from behind, the road was smooth so i assumed it was a backfire not a suspension issue.
is it normal for the car to backfire like that? my a/f ratio is fine i'm not running too rich, but it rare for this to happen. car was warmed up well since i was already on my way home.
TIA!
-Anton
Old Aug 12, 2010 | 07:50 AM
xmaciek82x's Avatar
Is your car stock?
Old Aug 12, 2010 | 09:09 AM
XxApollynxX's Avatar
Try to replicate the problem again by doing the same thing on another flat road you already cruised down and know there is no bumps. What are the mods on your car?
Old Aug 12, 2010 | 09:12 AM
SwishaSweet's Avatar
The tranfer case will make a loud bang if you shift too fast too hard are you sure you just wernt kickin butt. Also try it at night because you can see a big flash if you back fire.
Old Aug 12, 2010 | 09:20 AM
anton406's Avatar
mods in car full exhaust, intake, BOV, tune.
Old Aug 12, 2010 | 09:28 AM
Drew_FL's Avatar
Maybeeeee.. because i threw a test pipe in my friends and he started backfiring.
Old Aug 12, 2010 | 09:32 AM
xmaciek82x's Avatar
Well depending on the tune, it might be backfiring. Test pipe or cat?
I'm pretty sure that is the rear diff making the noise and not the TC.
Old Aug 12, 2010 | 12:15 PM
4g63Moon's Avatar
I dont think it was a backfire because you stated that you weren't running rich? But if you have a testpipe,f pump,injectors and a tune, you def will backfire.
Old Aug 12, 2010 | 12:36 PM
TouringBubble's Avatar
Is the BOV open or recirculated?
Old Aug 12, 2010 | 12:48 PM
BOV is to the Atmosphere car goes way rich when you shift causing back fire now buy me a beer.
Old Aug 12, 2010 | 12:56 PM
tweakdsm's Avatar
Normal, car gets rich between shifts sometimes, and it pops. you get that more often if you VTA on stock ecu.
Old Aug 13, 2010 | 06:31 PM
Sacevo9mr's Avatar
i have headers, full exhaust and test pipe and never back fire :/ i wish
Old Aug 13, 2010 | 06:43 PM
NJ_EveOhVIII's Avatar
^2nd that (VTA BOV, catless, big injectors, tiny turbo)
it happens on wot shifts or when double clutching for me.
Old Aug 13, 2010 | 06:53 PM
Drew_FL's Avatar
What headers....
Old Aug 13, 2010 | 08:31 PM
compscibOi's Avatar
lmao @ headers.... oh boy.
