Fair comparison between the viii turbo and ix turbo
Old Aug 27, 2010 | 10:04 AM
BOOSTINAT30PSI's Avatar
I figured i would post this here. If the mods decide to move.. So be it. I apologize!!!
Ok.. So i have a 2004 evo viii rs. It is currently in the bodyshop due to an accident ad they said that "flapper for the internal wg" was damaged. I should look into a new turbo. I have been reading much on the differences between the evo viii turbo and the ix turbo. Now i cant find the answers i seek!!! I been searching for dyno graphs comparing the two.. Or infor supporting peoples "gains" by going to the ix turbo etc.
Now here is the question...
If there a good enough difference to maybe "upgrade" to the ix turbo? If anyone can show dyno sheets to support their answer... Or even let me know what they made on the viii turbo and then what they made if they upgraded to the ix turbo.
Any info will be appreciated! Thank you
Old Aug 27, 2010 | 03:13 PM
DRsnoopy's Avatar
Depending on money, why not upgrade to fp green? You know there is a power difference there. My view is, when something breaks, time for upgrade.
Old Aug 27, 2010 | 03:19 PM
High_PSI's Avatar
Get atleast a Green Turbo. The IX makes more power then the VIII for sure though but just get a FP model, any of the three are fine.
Old Aug 27, 2010 | 03:20 PM
vanilla2's Avatar
Id go bbk if i was you
Old Aug 27, 2010 | 05:05 PM
Whats the hype with the fp turbos? Ok... Im not originally an evo guy. I have a t67 h.o. P trim sitting... And i was going to use it for my civic turbo build. My buddy at the shop said to use that turbo on the evo and put something a bit smaller on the civic.
My thing is... What do i as far as putting what turbo on?
Old Aug 27, 2010 | 05:09 PM
Evoryder's Avatar
Many threads covering the comparison for the two turbos. If you have the money just buy the IX turbo. It will give you more hp mid -top.
The cheap way would be for you to just a buy a used 10.5 hotside for $100 -150 vs $400+ for the IX turbo. You need to upgrade the j-pipe, wastegate for the ix turbo swap
Old Aug 27, 2010 | 05:14 PM
4RETECH's Avatar
Sorry to say I would upgrade to a BBK and not just a IX turbo.
With the BBK or FP's you can use the stock manifold and downpipe, I think that's why people are recommending them.
Old Aug 27, 2010 | 05:21 PM
Arent those on the pricey side?
Old Aug 29, 2010 | 10:15 PM
ezz-e's Avatar
yes they are but it simply falls in that list of mods you never regret
Old Aug 29, 2010 | 10:29 PM
noypiC50's Avatar
Bang for buck the evo9 turbo upgrade is awesome. I switched from a 03 evo8 turbo to an evo9 turbo and don't regret it at all. On the 03 evo8 turbo with basic mods( intake,tbe, hiflow cat) i made 265whp with custom tune. I then installed the evo9 turbo(ported hotside and exh manifold) and made 286whp running slightly less boost up top because i was maxing out the stock injectors. Gains all throughout the powerband and as much as +28whp increase in the midrange with no loss in spool. I actually felt the spool was slightly better with the evo9. if you had $1700 to spare by all means get a cbrd bbk or fp red etc but if you're budget only allows you about $500-600, cant beat the evo9 turbo upgrade.
Old Aug 30, 2010 | 06:32 AM
CBRD's Avatar
let me know if there is anything I can answer or help with!
sincerely
cb
Old Aug 30, 2010 | 10:37 AM
jdub187's Avatar
I have an old fp green I just took off my car, willing to let it go pretty cheap pm me if interested.
BlueEvo8JDM
Sep 30, 2010 12:27 PM
ethan169
Mar 30, 2010 02:56 PM
jcdevo67
May 10, 2008 01:01 PM
sloAZevo
Dec 23, 2007 05:23 PM
adrynalinjunkie
20
Oct 13, 2007 09:00 PM
