cams require tune asap?
Old Sep 3, 2010 | 07:25 PM
OMEGA PHX's Avatar
Don't risk your car, it should be fine as long as you take it easy but your taking a big risk.
Old Sep 4, 2010 | 04:44 AM
MR. EVO MR's Avatar
Or, or install them the day before you get tuned.
Old Sep 4, 2010 | 06:51 AM
4RETECH's Avatar
Originally Posted by 4WS Tuning
You'll be okay driving the car under 10psi boost, but I wouldnt drive the car wide open throttle unless you have at least a base map.
Cheers!
Also, if you don't have your base map for the kelfords, your car will hunt for idle and want to stall at stop lights.
Old Sep 5, 2010 | 10:00 AM
OMEGA PHX's Avatar
Thats right the untuned ecu will try to compensate for the cams and you will have a hardtime before the tune, install them the day before the tune or at the tuner.
Old Sep 6, 2010 | 01:41 AM
EvOstyleZ's Avatar
Hmm lots of good points have been brought up...
Im about an hour away from the shop im getting it tuned at, so ill most likely have to do HIGHWAY driving the whole way there.
For those of you who said just put them in at the shop, do you mean have the "shop" put the cams in? Or me putting the cams in "myself" at the there "shop"
That would be pretty cool if choice two was actually allowed, not sure
Old Sep 8, 2010 | 05:33 PM
blknblubkrdude's Avatar
As long as you aren't running around at WOT there is nothing to worry about.
A had to do this as I was out of state when I installed my cams and had to wait for a tune.
Old Oct 2, 2010 | 01:00 PM
JonahEVO's Avatar
Do you have a RS or a Sti??? Kinda weird that you drive a STi but talk like you have a Evo. For the Op, you should be fine driving around but just don't hit boost until you get a TUNED.
Originally Posted by 2004-WW-RS
I got mine tuned as soonest i bought the car, didn't know if it was tuned before tho.
Old Oct 2, 2010 | 02:06 PM
CammedEvo's Avatar
log for knock and afr's..
Also your putting a rather large cam in it may not idle well.
I would just get a basemap from your tuner pre-flashed
Old Oct 2, 2010 | 04:57 PM
Guppie1337's Avatar
I say do it the weekend before your tune and DON'T forget to bleed the lifters. Get AAA and have it towed... no point in risking anything.
Old Oct 2, 2010 | 06:50 PM
Spoolin4g63's Avatar
your car will be fine..! i installed mines on a sunday and had to wait until friday to get tuned..! just stay outta boost and dont get on it..! you will be fine..
supafly_mx
Jun 10, 2015 08:55 AM
1fast97gsx
Nov 28, 2014 10:07 AM
wshihdnevo
Nov 17, 2008 11:48 AM
vipers
Jan 11, 2008 02:01 PM
SavEVOIX
Dec 21, 2007 08:35 AM
