HFC vs test pipe
Old Sep 8, 2010 | 11:10 AM
OakosAutomotive's Avatar
Originally Posted by EVOL2003
dude just get a test pipe its not that much louder and you will have piece of mind. the car is load anyway lol
x2. The test pipe barely makes the car louder. I have a TXS test pipe in my car right now.
Bart
OAKOS Automotive
Old Sep 8, 2010 | 12:01 PM
EVOL2003's Avatar
Originally Posted by MechTech
maybe i just don't get it but wat are you talking about with smell? as long as it seals right and ur gaskets aren't garbage there shouldn't be any smell. This question confuses me
Originally Posted by flmr06
some people say that without a cat you can smell whatever unburned air/fuel mix is coming out of your engine/exhaust. I personally have never experienced any smell from removing the cat on any of my cars in the past. Some people are a bit more paranoid about this than others.
there is no cat to stop(filter) the exhaust so there is a smell....it not unburned fuel if you have a good tune
Old Sep 8, 2010 | 12:08 PM
mifesto's Avatar
reason why you get different opinions about test pipe smell is because every car is different. cars with cams will have worse smell as their idle will suck (compared to stock cams); hence more unburned fuel from lopy idle. also very skilled tuners can reduce the lopyness of cams and hence reduce smell....
the reason why i stick with test pipe mostly is the price. HFC's are almost double the price of resonated test pipes.
Old Sep 8, 2010 | 12:53 PM
Raptord's Avatar
There is a very slight exhaust smell in my garage, but other than that I've never smelled any exhaust gasses with my TP. The exhaust also isn't that loud, when I got it sound checked at a road course it came out to 91.8 dB at 5k rpm in neutral from ~30ft behind the car.
Old Sep 8, 2010 | 12:59 PM
mifesto's Avatar
yeah test pipe doesnt make it a huge difference in the end regarding noise, type of muffler is the key. smell wise, mine does smell slightly while idling but its not horrible.
Old Sep 8, 2010 | 01:08 PM
one4's Avatar
both will smell. test pipe will be worse but its not too bad anyways. imo a hfc isnt worth it. if you want better flow without the smell, get a 3" truck cat, best flow is of course with a tp
Old Feb 20, 2013 | 09:25 PM
EvoTurboTurk's Avatar
If the tune is good on a evo with 3" straight pipe tbe replacing the hfc, would my car pop, flame or backfire?
Evolpixy
May 11, 2017 11:26 AM
TxFAkuma
Jul 8, 2016 08:10 AM
the_evodude
Jan 10, 2014 09:28 AM
Fireescape
17
Feb 28, 2012 07:14 AM
nefarious_Saint
Jan 17, 2011 09:05 AM
