Removing PCV valve before powdercoat?
Old Sep 19, 2010 | 11:12 PM
Svendiesel's Avatar
I just tried removing my PCV valve on the back of the valve cover because Im getting it powercoated tomorrow. I got a wrench on it and tried removing the fitting but it just keeps spinning, am I missing something is there a special way to remove it??
Do I even need to remove it or can I just leave it?
Old Sep 20, 2010 | 08:16 AM
boostedwrx's Avatar
Take a screw driver and wrap some rubber or leather around it. Use it as a pry-bar to pry the PCV out of the valve cover. This is what I did and it plopped right out without damaging anything. I then threw the PCV in the garbage can & replaced it with -6 fitting. I'll be using catch can without recirc back into the IM.
Old Sep 20, 2010 | 09:51 AM
chaotichoax's Avatar
you can leave it as long as it is taped off
otherwise it needs to be spun towards the valve cover and it'll come right off
Old Sep 20, 2010 | 09:56 AM
ct78155's Avatar
Every coater will do things differently, but we always remove the pcv valve and block off the threads. If you tape it off, chances are they will still get some coating on the end of the pcv valve. Powder coat is thick, if for some reason you need to remove it later down the road you'll either have problems taking it off OR you'll be able to remove it but also take the powder coat along with it.
___
Carlos Tirado
Old Sep 20, 2010 | 10:42 AM
boostedwrx's Avatar
It's just a fitting, it's not threaded at all so it won't come out unless you pry it out, or pull while turning it.
Old Sep 20, 2010 | 10:49 AM
ct78155's Avatar
Sorry but that is incorrect, the pcv valve does have threads.
There are 2 parts: a fitting that is on the valve cover, and the pcv valve that threads onto that fitting.
Old Sep 20, 2010 | 10:54 AM
not sure where you got this from
as Carlos stated above the pvc valve is threaded onto the fitting pressed into the valve cover
Old Sep 20, 2010 | 11:38 AM
javicracer's Avatar
i need that stupid fitting, any chance someone is selling that?!?
Old Sep 20, 2010 | 11:39 AM
boostedwrx's Avatar
Yea you guys are correct that the PCV itself is screwed into the fitting (that goes into the valve cover). If your going to powder coat I would remove the entire PCV and fitting (and to get the fitting out i'd pry it out like I explained). If you take the PCV valve off first you'll have more trouble trying to pry the rest of the fitting out.
Old Sep 20, 2010 | 08:15 PM
Svendiesel's Avatar
Ok so the whole fitting itself needs to be pried out, sorry I shoulda been specific I know the valve part itself screws in, but I want the entire thing off the valve cover. It needs to be pried?
Old Sep 20, 2010 | 08:22 PM
Tiradocc's Avatar
That is correct, you can use some pliers and it shouldn't be too difficult to take off.
Old Sep 21, 2010 | 08:00 AM
boostedwrx's Avatar
Hehe yea thats how I took your post, everyone else just thought you were removing only the check valve itself.
Hey its cool to see TCC is a Silver Vendor now right on!
Old Dec 15, 2010 | 05:39 AM
Yota Eater's Avatar
Veteran: Air Force
The fitting is part number: 1057A033, gasket, pcv valve.
Old Dec 15, 2010 | 08:13 PM
Betty's Avatar
I powdercoated my valve cover and that piece was powdercoated too. I didn't remove it and I have had 0 problems.
craig05evo
Apr 21, 2017 06:07 PM
BonsaiScott
Dec 19, 2016 04:26 PM
aamoedo
Oct 28, 2016 09:22 AM
aamoedo
Apr 24, 2013 10:53 AM
DrDeC
Apr 6, 2012 07:19 PM
