low boost
Old Oct 17, 2010 | 03:06 PM
Billy05MR's Avatar
low boost
I just put an exhaust manifold and o2 housing on my evo. the car is stock other than bolt ons. I'm only getting 10psi. I dont have any boost leaks. Whats going on?
Old Oct 17, 2010 | 06:14 PM
S0rc3r3r's Avatar
what brands of parts did you go with? what parts do you have? what did you have to remove to do the install?
Old Oct 17, 2010 | 08:14 PM
Andrewkbmx's Avatar
sounds like a massive boost leak running wastegte pressure check the vacuum line running off the wastegate for holes
Old Oct 18, 2010 | 09:08 AM
Billy05MR's Avatar
Both parts are MR. I have an injen intake, injen upper and lower intercooler pipes, and Buschur TBE. To put the manifold and o2 housing in i had to take the turbo out of the car.
Old Oct 18, 2010 | 07:13 PM
Billy05MR's Avatar
bump
Old Oct 19, 2010 | 12:32 AM
pwrofturbo's Avatar
Either you have a boost leak, the wastegate signal line is hooked up without being routed through a boost controller (stock or aftermarket), or you have a huge exhaust leak before the turbo.
Old Oct 19, 2010 | 02:19 AM
white_evo27's Avatar
+1 for exhaust leak
Old Oct 19, 2010 | 07:26 AM
evo8426's Avatar
I would go back to the manifold, loosen the nuts and then re-torque them from the center then right then left, ect until all have been torqued, then i would re-torque the bolts and nuts at the turbo to manifold.
Did you mess the the wastegate arm when you put the o2 housing on?
Old Oct 19, 2010 | 09:14 AM
Billy05MR's Avatar
I didnt mess with it. But the whole turbo with the wastegate was out of the car sitting on my work bench. Ill try the exhaust leak but if there was a leak there would be carbon around that area and there isnt any. I appreciate everyones input
03EVOGUY
May 18, 2016 04:21 PM
Kevoix
Apr 10, 2016 10:12 AM
jjacks55
Feb 25, 2014 04:59 AM
347-dis
28
Aug 23, 2012 05:21 AM
bellorz
Apr 24, 2011 07:53 AM
