ses light question
Old Oct 18, 2010 | 02:46 PM
jsayers's Avatar
ses light question
my light came on and i pulled the code and it said random/ multiple cylinder misfire. P0300 was the code. when i started the car after pulling the code the light was no longer on. what does this mean?
Old Oct 18, 2010 | 09:44 PM
gsrboi80's Avatar
Sounds like you may have pressed the button on the scanner to clear the code
Old Oct 19, 2010 | 12:57 PM
jsayers's Avatar
but wouldnt the light come back on if the problem isnt fixed?
Old Oct 19, 2010 | 01:20 PM
chaotichoax's Avatar
p0300 is a code that has randomly plagued earlier evo 8's for many years...they have patches to block the code within ecuflash
Old Oct 19, 2010 | 03:46 PM
EVO8STI's Avatar
i live with it every day. i just carry around a obdII reader. its never not plugged up =(
Old Oct 19, 2010 | 08:49 PM
gsrboi80's Avatar
It may take a few drive cycles to trigger the code again. P0300 codes on the early VIII's are common. Mitsu actually had 2 rom updates to address the issue and what they concluded is that drivetrain harmonics would trigger the code. This would show it's ugly head even quicker with cars with aftermarket clutch combos
For the problematic cars that the rom updates would not fix as Chaotic mentioned best bet is to just have it disabled in the ROM and you'll never have the issue again.
Some other things that I would rule out prior to disabing the P0300 code are:
-Ignition components (Coils, Wires, Plugs)
-Ignition map idle timing. Too high of values in those cells will trigger P0300. These are often adjusted to make big cams play nice at idle
-Ignition map smoothing. As large timing value gaps from cell to cell in the ignition map can also make the ECU throw the code.
When does your car throw the code idleing, around town driving, highway crusing?
If you have tactrix cable and ECUFlash P0300 fix is only a flash away. If you need any assistance PM I'd be glad to help
bluegsr
Jun 18, 2010 05:22 PM
775evo
12
Jun 17, 2010 02:25 PM
er0e
May 20, 2010 01:22 AM
malves85
Dec 15, 2009 08:03 PM
MDH-005
Apr 14, 2009 04:41 PM
