balance shaft eliminator
Old Jun 5, 2011 | 12:30 PM
  #31
Murf's Avatar
I have the AMS race delete kit, and use all the stock pullies with no troubles.
Old Jun 5, 2011 | 09:23 PM
  #32
reboundicon's Avatar
I have the kit on my EVO and honestly there are not many added vibrations. Unless you have full motor mounts, I don't think you will notice that much of a difference. Definitely a good mod and 1 less failure point for the EVO IMO.
Old Feb 21, 2013 | 01:14 PM
  #33
dawidevo's Avatar
im building 2.3 stoked motor right now and im not sure if i should delete my BALANCE SHAFT ??
i always delete it in my gsx but im new to evo's
please help thnkss
Old Feb 21, 2013 | 04:11 PM
  #34
Throttle's Avatar
i'm interested in doing this as well. from what i have heard this mod has no negatives. engine reliability is the same or better. i'll most likely have english racing do this mod since i don't wanna do it myself. i'll see what they have to say when the time comes.
Old Feb 21, 2013 | 07:34 PM
  #35
SmurfZilla's Avatar
please help thnkss
Duuuuu it.
Then you will get into the inevitable AMS/GSC/Insert Brand Name BSE and the OEM BSE and which one is better.
Old Feb 22, 2013 | 03:30 PM
  #36
Throttle's Avatar
Originally Posted by SmurfZilla
Duuuuu it.
so... which one is better?
i didn't know mitsu makes an eliminator kit.
Old Feb 22, 2013 | 10:02 PM
  #37
SmurfZilla's Avatar
Its know as the stubby shaft. It is from the turbo colt. Its the OEM solution to the BSE. The turbo colt has a 4G63 in it so for most people (myself included) they figured if it was good enough for a OEM production car then it should be fine.
The AMS/GSC kit provides a more "elegant" solution to this. Its been endlessly debated which option is better with intelligent points made for or against either solution. THey both work but its all in the install is what I've gathered from the numerous debates.
Old Apr 4, 2013 | 02:00 PM
  #38
AKW89's Avatar
When I got my car I was warned that the bearing was failing on my balance shaft... let me rephrase this... a person who had the car before me was an didn't let me know. The engine was wonderful, they didn't let me know and the bearing locked up. The balance shaft stopped spinning, oil started pouring, the timing belt broke destroying the head, the pistons, everything. The FIRST money I spent on my car was getting that damn thing out. Bought an OEM Mitsubishi delete kit, had the motor balanced throughout the build, and NEVER want to see another balance shaft again. It is just a matter of time if you still have one in your car, and trust me... you don't want that to happen.
Old Apr 4, 2013 | 04:57 PM
  #39
304MR's Avatar
How many miles were on the motor when it failed?
Old Apr 4, 2013 | 06:40 PM
  #40
batty200's Avatar
QFT! Get rid of it if you have a chance.
Old Apr 5, 2013 | 06:28 AM
  #41
AKW89's Avatar
Around 15,400 when the balance shaft locked up
Old May 22, 2013 | 05:35 AM
  #42
TommiM's Avatar
bumpin this thread. I am finishing up my my bse install. I installed new oem bearings rotated 180 deg, installed the oem stub shaft, got the little plug cover for the balance shaft, and installed the spacer to replace the balance shaft sprocket. As far as ditching the balance shaft tensioner pulley, I want to find a shorter bolt to thread in its place. Is that what everyone else is doing? Cant seem to find info on that.
Old May 22, 2013 | 06:33 AM
  #43
batty200's Avatar
I just leave the pulley. I also just leave the factory gear instead of using a spacer. The factory gear is 100% the right size. Why mess with perfection. You can use a smaller bolt and I do that sometimes but it isn't necessary. Since it isn't visible either I usually just leave the pulley in there.
Old May 22, 2013 | 07:25 PM
  #44
TommiM's Avatar
I do like the way the factory gear supports the trigger wheel better, but at the same time I don't feel that is really an issue.
RAPPER8521
Jul 3, 2017 01:06 AM
honda-guy
40
Aug 2, 2015 07:37 AM
CrawlinTBSS
Jan 23, 2012 12:57 PM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
Yamahar1
Jul 11, 2009 02:38 PM
