Boost Issues
Old Nov 13, 2010 | 06:23 PM
Countrystrong11's Avatar
Boost Issues
Ok so i searched this and didnt really find anything to help me out.There are plenty of threads about it, i even posted on one to see if someone would help me out but no such luck.
So i just installed a boost gauge in my 06 Evo and no matter what gear and how hard or slow i mash the throttle it only goes up to 11psi. I checked all of my connections. And about a month ago the car just didnt seem as fast as it was when i first got it.
A little bit of history of the car, I bought it from a dealer, the ecu was screwed up so the replaced that, then the clutch went so they replaced that, then the serp. belt broke got caught up in the timing belt, so new valves. I have been having problems with this dealer since day one.
So anyone have any sugestions, im somewhat new to this whole turbo engine thing. So anyhelp would be awesome.
Old Nov 13, 2010 | 06:25 PM
shrtstuff89's Avatar
when i purchased my '03 evo, it too was merely 11psi. took a tune to boost it up to 18-19 psi
Old Nov 13, 2010 | 06:28 PM
4RETECH's Avatar
What?? Stock is 20.06psi tapers to 16 at 6,500 or something like that.
Old Nov 13, 2010 | 06:44 PM
4RETECH's Avatar
Country, pm me. I would like more info. I have a shop up there that might be able to help.
Old Nov 13, 2010 | 06:56 PM
kousayee's Avatar
i have the same problem, i did a boost leak test and found out that my throttle body seals are leaking bad.
do a test you will be surprised
also see if the previous owner had a mbc installed, they might of swithched things around when returned to stock
Old Nov 13, 2010 | 07:00 PM
Im goin to do the boost leak test just need to figure out a way to do it without a compressor avail.
And how would i be able to tell if they had a boost controller on it?
Old Nov 13, 2010 | 07:19 PM
FQ-300's Avatar
Sounds like you are running wastegate boost pressure 11-12 psi. You might want to start by checking there.
Old Nov 13, 2010 | 07:25 PM
How would i check that?
Old Nov 13, 2010 | 07:31 PM
novem's Avatar
There is a line coming off the turbo elbow [ the black pipe that comes off the turbo] and another
line coming off the waste gate. both lines should merge and go to the boost solenoid [or manual boost controller] if that is not clear take off your air filter so you can take a pic and post it on here.
N
Old Nov 13, 2010 | 07:37 PM
N
I will take a look at that tomorrow morning. Ill snap some pics for you guys to help me out, thank you so far for all the help. Hopefully i can get this figured out
Old Nov 14, 2010 | 10:01 AM
Ok here are some pics i just took, The first one is from the turbo and wastgate side of things....and the second is from under the air box.(This piece was zip-tied in place, and the clamps where like that when i took the pictures.) So i know the car has been apart.
So are these lines on right or do they need to be switched?
Old Nov 14, 2010 | 11:10 AM
I found another picture of these and it looked like my lines where switched. so i switched them and i still get only 11psi, i also tightened all of the boost fittings, and intercooler pipes that i could get to.
Old Nov 14, 2010 | 03:16 PM
Bump....anybody?
Old Nov 14, 2010 | 08:22 PM
sparky's Avatar
Iīd take a trip down to your local Mitsu dealerīs parts department and for $17.00 you should pickup the factory vacuum-boost hose assembly. This comes with the original T and the inline restrictor orifices.
Next, after installing the above, I would increase wastegate spring pressure up to about 17 PSI for starters.
Old Nov 15, 2010 | 09:25 AM
Ok, ill take a trip down there sometime soon. and how do i change the wastegate spring pressure?
