Blew my motor!! so much for the FP Black on the stocker!
Old Dec 10, 2010 | 10:45 AM
  #121
LGshow19's Avatar
looks like u threw a piece of c4 in there lol
Old Dec 10, 2010 | 10:46 AM
  #122
murlo26's Avatar
I wanted to do some weight reduction so I put a nice window through the block...great for Aero too.
Old Dec 10, 2010 | 11:45 AM
  #123
tscompusa2's Avatar
that sucks dude. Mikes discounts FTW. I bought my entire engine from him and half my car parts.
Old Dec 10, 2010 | 12:00 PM
  #124
High_PSI's Avatar
Originally Posted by EvolutionVIIIrs
yea, it was pretty aggressive tho.. Then again, it was only at 27lbs. And the motor only had 38,xxx miles on it. But shes been though alot. But like i said. Now ill be shooting for 9s!!
So FP black, on E85 ( AMS intercooler, AMS short route IC piping, Fidanza cam gears, BR double pumper, FIC 1450cc injectors, Hallman Pro BC, Spoolin up COP kit, Speed Density, )plus the new shopping list
BR 2.0, BR stage 3 head, AWD 272 cams, L19 ARP headstuds, OEM Mitsu Engine gasket set, OEM Mitsu front cover w/ oil pump and gears, and Evo 8 AC delete sound good?
If it blew at 27K it was more then likely a tuning issue. Cold? I imagine it went lean. Go 2.0 block and be done with it.
Old Dec 10, 2010 | 12:12 PM
  #125
tscompusa2's Avatar
update! Well i pulled the oil pan off last night. Guess what i found? lol
Half a rod with the wrist pin, that had punched the two holes in the pan, and then just stayed there long enough for the crank to rotate over it a couple of times. So the cranks toasted! ill add some pictures later tonight.. Parts are gettin shipped to Buschur this week thanks to Mike @ AWD!!! This is gonna be a serious build!!!
Oh and on top of that, it started snowing today! looks like ill be doing the motor/trans install in the snow!!
I have a oil pan in my garage if you need it. It was my old pan when i spun a rod bearing from oil starvation. It was hot tanked and cleaned at buschur racing but i had already ordered a new one from MAPerformance. So if you need it let me know.. $40 + ship. its just taking up space. i also have a lot of OEM gaskets that maybe you could use that are all brand new of course.
Old Dec 11, 2010 | 07:49 PM
  #126
EvolutionVIIIrs's Avatar
Yea he is Hookin a brotha up!!
37,xxx miles to be exact. lol.. Its just too much power for the stock bottom end to hold together. And the buschur built 2.0 is already in the works!
Thanks for the offer man. but it goes back to Mike hookin it up!! Hes got me covered on everything already!!
And I DO have two holes in the block. Its a true window thru the 4th cylinder. I think page 5 has the picture where you can see straight thru the block!
Im currently working on ideas as to what i can do with the block once i clean it up. Im thinking some kind of table base or something, with a piece of glass over it. I just cant bare to toss such a special piece of history for my Evo!
Old Dec 12, 2010 | 01:03 AM
  #127
LGshow19's Avatar
Table that block, should be pretty cool to walk in and see a block for a table infront of the TV hahahha
Old Dec 12, 2010 | 12:52 PM
  #128
oneofakindtrini's Avatar
What kind of mileage is your stock motor at? It should have held 500whp. Any alcohol or meth?
Old Dec 12, 2010 | 12:55 PM
  #129
Evokid03's Avatar
Mine had a hole on the other side of the block as well, also took of a chunk of aluminum on my tcase
Old Dec 12, 2010 | 06:04 PM
  #130
I was running meth, but as previously stated, its not so much the amount of horsepower i had, but the wheel torque.
Yea, I was VERY lucky to not have anything but the block, crank, and oil pan go. VERY lucky!!
Old Dec 12, 2010 | 06:42 PM
  #131
kakarot305's Avatar
**** god damn and to think that i wanted to put an fp black on my stock bottom end really sucks to see what happened bro
Old Dec 12, 2010 | 07:42 PM
  #132
Tagge's Avatar
sucks to hear but you def. have the correct attitude! and seems you are in good hands with mike!!
Old Dec 13, 2010 | 04:49 PM
  #133
DGrey8761's Avatar
I just did the same thing with a stock Toyota 4runner with 60k miles. Talk about a bad night. Sorry to hear about the motor man.
Old Dec 21, 2010 | 06:42 PM
  #134
been gathering parts. Sorry for the slow update.. pictures to follow! Ill be making a build thread once i start getting more parts back!
Old Dec 21, 2010 | 07:13 PM
  #135
on with more pics!
Its going thru the dash, but i just placed bars in places to get an idea.
And a pic of all the pieces including whats left of the rod and piston ring.
A close up of the half rod thats left
Trans/head and my OEM core fuel sending unit off to Buschur Racing!
