Funky Rattle
Old Nov 22, 2010 | 08:23 PM
SuperMoto!'s Avatar
Funky Rattle
Evo's are noisy beast but mine has developed a rattle in the front end after i installed a 3' downpipe. It doesn't make any noise cornering but I get a bit of a rattle when leaving from a dead stop. It's not the suspension, and everything is tight from the install (downpipe, cross beams, etc...) I'm wondering if it might be the undertray. If anyone has any ideas or experience with this I'm all ears. Thanks in advance
Old Nov 22, 2010 | 08:46 PM
WolfsFang's Avatar
DP is prob smacking into something.
Old Nov 22, 2010 | 08:52 PM
chaotichoax's Avatar
would make sense that the downpipe is hitting something
from a stop you are getting some initial engine movement and the exhaust shouldn't be very loud at the lower take off rpm so you hear it easily
it's either hitting the transfer case or possibly the tension bars below...could even be the test pipe touching the underside material from installing the downpipe
Old Nov 23, 2010 | 07:56 AM
evo8426's Avatar
downpipe is probably rubbing the sway bar. the sway bar is above the downpipe near where the hangers are
Old Jan 9, 2011 | 07:04 PM
SuperMoto!'s Avatar
Thanks for the help guys, the downpipe was making contact with the transfer case and sway bar.
Old Jan 9, 2011 | 07:14 PM
AKAweasle's Avatar
just curious seeing my exhaust is in the mail and might have this problem, was this a hard fix? or just some simple adjusting?
Old Jan 9, 2011 | 07:16 PM
evo8426's Avatar
adding exhaust wrap is what i did to cure mine, since then ive changed exhaust setups to an ams tbe and it does not rub the sway bar or tie bars
Old Jan 9, 2011 | 07:25 PM
AKAweasle's Avatar
oh ok i was going to wrap mine anyways. thank you for your quick reply
SuperMoto!'s Avatar
Pretty simple adjustment but takes time (I've had my DP in and out a few times to get it right) but if your not comfortable making them, any reputable muffler shop could do the same and should not cost you an arm and a leg.
Old Jan 9, 2011 | 07:36 PM
AKAweasle's Avatar
i'm not uncomfortable with it, put exhaust on my sti and mustang no problem and my srt-4 exhaust went on good after i dremeled through my brake lines (little rough patch) lol but i just wanted to see if there was something i had to do to make this not happen.
TurboNubCake
May 19, 2016 09:53 AM
Rival Legendary
Jul 7, 2015 06:34 PM
boobcakes
Evo X How Tos / Installations
55
Dec 19, 2011 10:05 PM
twinturbogreg
Aug 9, 2010 07:58 AM
WADADLIG_OZ
14
Feb 20, 2004 03:57 AM
