blower fan lvl only works on 4
Old Dec 13, 2010 | 10:21 AM
gallas's Avatar
ok to start i searched and i assume that this is a common issue. but just a few days ago my a\c blower control knob only works on lvl 4 and nothing works below that... any one have any clues? maybe just a faulty unit and needs a replacement?
Old Dec 13, 2010 | 10:30 AM
jasons9594's Avatar
My first guees is the blower motor resistor is bad....
Old Dec 13, 2010 | 10:31 AM
EvoJoeIX's Avatar
Need a new resistor
Old Dec 13, 2010 | 10:40 AM
Alexl08's Avatar
^^^ +1 thats your problem for sure unless 1 2 and 3 contacts on the switch are worn down so bad they dont make contact but highly unlikly
Old Dec 13, 2010 | 11:30 AM
Dallas J's Avatar
Veteran: Army
Just to elaborate, the blower resistor has 3 resistors in it for 1, 2, and 3. The 4th speed runs the fan at full power and bypasses the resistor pack.
So pretty much anytime you see a 1-2-3 failure its the res pack.
Old Dec 13, 2010 | 02:04 PM
tarmac03's Avatar
+1 its the resistor its located in the top of the heater box behind the glove box. It only takes a couple minutes to replace it i think there is a how to on here some where
Old Dec 13, 2010 | 02:33 PM
TunerHead24's Avatar
Has anyone suggested the resistor? Lol
Old Dec 13, 2010 | 03:58 PM
gallas's Avatar
great i was hoping it would be an easy fix if that is what the problem is. but yes does any one have the resistance ohms? im still a little unclear, so their are 4 different wires that splice into one coming from the heater controls? and 3 of those resistances are burnt?
Old Dec 13, 2010 | 04:36 PM
tarmac03's Avatar
no it is a factory sealed unit that the wiring harness plugs into. what happens is the soldier joint comes loose and the speed control circuit becomes open.aka no power to the fan on the speed contrtolled settings. this is a common problem that accures the part is about 100 bucks from the parts store or you can get one from the junk yard from a regular lancer they are the same.
Old Dec 14, 2010 | 10:11 AM
gallas's Avatar
does anyone know the how to link
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
amsevokid
May 26, 2014 05:24 PM
Jlui83
Outlander Sport
15
Jan 24, 2014 09:02 AM
19DB794
Jan 2, 2014 05:21 AM
taylor25
Lancer How Tos / Installations
Sep 16, 2008 09:22 AM
