Is there a time limit on the servicing the timing belt?
Old Dec 17, 2010 | 03:55 PM
5 ltr. beater's Avatar
....Mitsubishi reccomends you change the timing belt every 60k....but what about timewise? is there a certain amount of time that can pass that mitsubishi reccomends changing the timing belt? or is it just plain ol' every 60k miles?
Old Dec 17, 2010 | 04:00 PM
TommiM's Avatar
The rubber in the timing belt can wear and dry rot over time. I dont think you have to worry so much about that unless you NEVER drive the evo. What year is your evo and how many miles do you have? In one case I would do a timing belt for age vs mileage is if you had a 1980s car w/ 38k miles on it
I think if you have an 03 evo and your at 40k today, I would just wait till your at 60k, imo.
Old Dec 17, 2010 | 04:02 PM
ak47po's Avatar
Old Dec 17, 2010 | 04:04 PM
mifesto's Avatar
my personal belief is 60k is a "safe" interval unless you abuse it. on most DD you can probably go over that somewhat without worry.
Old Dec 17, 2010 | 04:18 PM
well the car is just my weekend track toy as i have a DD.
i put only about 100 miles a week on it. sometimes less. its in the garage all the time.
my car has 51k miles on it. i wanted to save up for cams so that when i get my timing belt done, i can have cams installed at the same time (since most of the topside will be dissassembled).
so i wanted to put off doing the timing belt as much as i could (so i can save up for cams) but as im doing that, i just dont want the timing belt to age on me and possibly snap.
Old Dec 17, 2010 | 04:53 PM
grayw's Avatar
The JDM service interval is somewhat different from the maintenance schedule above, it's 45k or 5 years whichever sooner. Most of the time it's actually the balance belt that causes problems, if that lets go it can jam the cambelt.
When the belts were changed on my VIII at around 5 years, the balance belt was in a shocking state, and most of the tensioners needed replacing also.
Old Dec 17, 2010 | 11:48 PM
MRwanTon's Avatar
If you are not driving the hell out of your car i don't see why you would need to replace your timming belt at manufacurers schedule timing. 60k is a safe spot and 'recommended'. How long do you intend on pushing it? Just curious.
Old Dec 18, 2010 | 11:21 AM
i was planning on trying to have it last me untill about 57-58k.
im not drving the heck out of it but i am pushing more than the factory boost setting and i do some spirited driving about once a week.
Old Dec 18, 2010 | 12:44 PM
MRwanTon's Avatar
^^^^^You'll be fine don't swet it even if it passes 60k
Old Dec 18, 2010 | 12:47 PM
gieri002's Avatar
You will be fine, mine was replaced at 83K on my 03....I bought it with that many miles on it before I replaced it!
Old Dec 18, 2010 | 12:51 PM
ch1215g's Avatar
SUSPECTED SCAMMER
how do you know your timing belt wasnt replaced at 80k im at 85k right now
turbonium916
Jul 6, 2016 02:10 AM
turbotalawd
Nov 20, 2015 12:13 PM
rob!
Jan 19, 2012 12:18 AM
Darius@AMS
Nov 12, 2007 09:04 AM
4WS Tuning
47
Dec 24, 2006 07:11 PM
