Any drawbacks to the older quartermaster twin disk?
Old Jan 20, 2011 | 06:55 AM
evoforlife's Avatar
Hey guys im looking for a clutch that will hold prob around 600 torque and 800awhp and am just wondering if the older QM twin had any drawbacks because i saw that they switched to a newer version, please reply i need a clutch soon for my build.
Old Jan 20, 2011 | 08:31 AM
chu's Avatar
chu
If you daily drive, or even drive on the street soemwhat often, then its not a good idea. Becasue its a twin disk, the friction surface is very thin, and wares out quick. Daily slipping of the clutch makes its ware even quicker...and these things dont like beign slipped.
Old Jan 20, 2011 | 10:53 AM
evoforlife's Avatar
My car is going to be just a weekend cruiser maybe driven 4 times a month
Old Jan 20, 2011 | 02:17 PM
KentStateTsi's Avatar
Veteran: Army
They make alot of noise. I picked up a nice vibration around 2800-4000rpm. Typical of solid hub multi disks. It is a really nice clutch don't get me wrong. Just makes some different noises and rattles.
Old Jan 20, 2011 | 05:43 PM
evoforlife's Avatar
Yeah i dont mind rattles, noise, or vibrations just as long as it holds power
Old Jan 20, 2011 | 05:48 PM
chaotichoax's Avatar
like chu said...if it's not a daily then go for it
they hold gobs of power they just lack life span
Old Jan 20, 2011 | 06:00 PM
BenJ's Avatar
They are a great clutch, both new and old. They are rated north of 700tq and the shifting is absolutely awesome with them, especially at higher rpm's given the light weight (19lbs).
The downsides, if you can call them that, are a little chatter and a max life of about 10k. There are many people who complain about these aspects of the QM, but when I'm making 1000+hp, I really can't expect things to be either a) quiet or b) last a long time.
Old Jan 21, 2011 | 04:47 AM
evoforlife's Avatar
Thanks guys and is the 19lbs the new version ir the old version and whats the difference between the two?
Old Jan 21, 2011 | 09:53 AM
BenJ's Avatar
The old one is 19lbs, the new one is said to be 4lbs heavier so 23lbs. New version is supposed to last a bit longer, have better street manners given its slightly higher weight, has a geared disc setup, and I believe that it is an 8 bolt vs the old that is a 6.
Dmx3alo
Mar 11, 2017 08:18 AM
russ72
Nov 22, 2014 04:55 AM
icrnk
Jan 17, 2011 11:31 AM
scheides
13
Dec 20, 2010 07:26 PM
edovio
14
Nov 16, 2007 09:55 PM
