Reset ECU procedure
Old Jan 24, 2011 | 11:58 AM
j_barcarse's Avatar
Question Reset ECU procedure
This may be a wierd question but once you have reset the ECU by pulling the negative, What EXACTLY is the REAL re-learning process? I just leave the car on idle for about 10 mins. But My car REALLY runs like crap if its not fully learned itself. Sometimes it takes way longer than 10 mins! It basically BOGS and dies..There have been times I drove off accidentally and everytime the clutch is depressed, my car would stall right away.
Old Jan 24, 2011 | 12:30 PM
trialsindude's Avatar
One of two ways I do it, either leave it idle for 10min or so or go for a drive. Sorry no more info here....! But it will eventually re-learn itself.
Old Jan 24, 2011 | 02:16 PM
4RETECH's Avatar
Takes about 10 minutes, depending on ambient air temp.
If you are still having problems, I would suggest looking into your ISC(or IAC).
It might be old,worn,slow and causing you to stall when coming to a stop or even idle will race up and down.
Good Luck
Old Jan 24, 2011 | 03:21 PM
EvoJoeIX's Avatar
my car has never ran any different after resetting the ecu
Old Jan 24, 2011 | 03:27 PM
fastcolt's Avatar
Id say you should have someone who tunes plug in and see what the dealio is.
Old Jan 24, 2011 | 03:35 PM
Inflame's Avatar
I just put a new batery in my evo... It ran exactly the same afterwards. ****, id even say it was running better!
Old Jan 24, 2011 | 03:48 PM
06RedRalli's Avatar
And it usually takes about 20 or so minutes for the fuel trims to reset as well...so that'd prob help a little too.
westmc
May 18, 2012 02:40 PM
Speedd
May 12, 2012 01:13 PM
xhomm02
Dec 8, 2011 01:04 AM
Crester
May 26, 2011 05:51 AM
Slad
Lancer Engine Management / Tuning Forums
Jul 26, 2009 09:41 AM
