Reset ECU - learning
Old Dec 5, 2011 | 03:29 AM
xhomm02's Avatar
Hi,
everytime I reset ECU (due to flashing maps) I have big problems with idle then. I have to let the car idle 10 mins in neutral and 10 mins in gear and only then the car is OK. What the hell can be so off after reset? (LTFTs are fine).
Old Dec 5, 2011 | 04:38 PM
richardjh's Avatar
Do you have changes in your nine Idle RPM maps?
I ask because a couple of days ago we identified some incorrect idle map address defs in EDM/ADM Evo X ROMs. 53050009 was one. The correct map addresses are now available for download from goldenevo.com.
The issue was, some map addresses were "shared" between two supposedly separate idle rpm maps. If anyone with these ROMs thought had gone through and revised "all" their idle rpms, they were mistaken.
Rich
Old Dec 5, 2011 | 04:44 PM
villero1834's Avatar
im a noob at tunning but wouldnt this be corrected on the warmup map since he sayd its only on the first minutes when he turns the car on
Old Dec 5, 2011 | 06:39 PM
lil ayzian's Avatar
wish i can help
Old Dec 6, 2011 | 11:19 AM
xhomm02's Avatar
no, it happens no matter of cold or warm engine
Old Dec 6, 2011 | 11:21 AM
xhomm02's Avatar
Rich
This sounds interesting - yes, I have increased idle on two from the 9 maps - from 700 to 800 RPM. But how would it be linked with ECU learning something?
Old Dec 6, 2011 | 11:23 AM
guswaym's Avatar
i have the same issue and if u drive and put the clutch in and hold it in while coasting the idle bounces but it goes away after 10 mins of driving or "learning"
Old Dec 7, 2011 | 08:18 AM
richardjh's Avatar
Not learning, but possibly the ECU switching between maps based on different conditions. Each map does a certain job for certain conditions...
...not that I've seen any explanation as to what those conditions are!
Maybe go back to square one with the idle speed tuning - get the latest XML defs, make sure they all point to sane (and discrete) maps, consider why you actually needed to edit them, why only two and not all of them, and so on.
But I digress. I just thought your issue rang a bell, and wanted to draw your attention to the recent tidy-ups of "Idle RPM" XML defs. Maybe the latest ones will help...
Rich
Old Dec 7, 2011 | 11:35 AM
xhomm02's Avatar
Rich
Well, it´s not swiching maps what is happening. If i let it idle for about 10 mins after reflash, I have no idle problems any more until new reflash.
I use latest Cobb ATR version, so new XML definitins for ECUflash would not help me ...
Old Dec 8, 2011 | 01:04 AM
Charles12345's Avatar
Benson830
Nov 8, 2016 09:32 AM
Dynafit
Nov 4, 2015 01:20 AM
Tri
Sep 25, 2012 06:20 PM
Viet-Speed
May 19, 2012 12:58 AM
westmc
May 18, 2012 02:40 PM
