Stroker kit that is high reving
Yes the ams blue demon uses the 2.3rr. I'm not sure how deep your pockets are but the 2.3RR block from ams is 8200. I'm sure you can build something else for far less than that with a built head also for that kind of money
There are a lot of threads out there about the stroker kits and 2.4 vs. the 2.4LR.
std rev limit of the 2.3 100mm/150mm = 8500
std rev limit of the 2.4 200mm/156mm = 8700
Not said that you can't take them higher, but the more stress you put on the motor the more negative effects it will have on the longivity. Kevin Kiggly revs to 9300 in a std rod 2.3.
Read this thread. https://www.evolutionm.net/forums/ev...ot-stroke.html
https://www.evolutionm.net/forums/8282453-post28.html
Thread. Closed. Research. There is a lot out on this topic.
benderrodriguez
13
May 27, 2010 03:56 AM
Johnboy1065
17
Nov 19, 2007 11:11 PM
chrsevx
14
Oct 16, 2007 03:48 PM
NocturnalEVO
May 18, 2005 11:20 PM
