which valve seals to use
Old Feb 21, 2011 | 12:34 PM
scothu's Avatar
I'm putting in kiggly beehives so I figured I would change the seals as well.
Supertech: http://www.cimotorsports.net/motor-s...l-set-evo.html
says it fits all valve springs?
Ferrea: http://realstreetperformance.com/sto...-evo-2263.html
OEM: http://www.tougefactory.com/shop/pro...ve-stem-seals/
or other?
Old Feb 21, 2011 | 12:37 PM
wht95scort's Avatar
Any will work as long as the springs are not DUAL. If they are then you would need to run the supertech ones.
Old Feb 21, 2011 | 12:41 PM
X91EVO's Avatar
Registered User
^^ why do you have to run the supertech seals on a dual valve spring?
Old Feb 21, 2011 | 12:42 PM
scothu's Avatar
ah I see they have 2 kinds now. so they are all pretty much the same?
Old Feb 21, 2011 | 02:24 PM
newbieEVO8's Avatar
Because with dual valve springs the inner spring can pull a stock sized valve seal off allowing oil into the combustion chamber.
Old Feb 21, 2011 | 05:30 PM
wht95scort's Avatar
Right, The stock seal is too large of a diameter to fit inside the dual spring.
Old Feb 22, 2011 | 02:14 AM
STi*guy.kiev's Avatar
supertech have premature failure... there is too much play in them
Old Aug 1, 2011 | 02:49 PM
ethan169's Avatar
How accurate is this statement? Im looking into replacing my worn seals and i do not want to but ones in that will just go out again in 20k miles.
Im running the GSC Beehive springs with S2 cams...
Thanks for any info..
Ethan
Old Aug 1, 2011 | 04:34 PM
4RETECH's Avatar
Ethan
I've had my supertechs in for at least 30k. No problems so far.
Old Aug 2, 2011 | 04:44 AM
ethan169's Avatar
Thanks for the info. Super tech it is then.
What cams and springs are your running? Stock retainers?
Thanks again!
Also are you running these smaller inner diameter ones? Im only on beehive springs so i dont have a dual setup.
Old Aug 2, 2011 | 06:40 AM
4RETECH's Avatar
Thanks again!
Kelford 272's with the Supertech dual spring setup and the 6.6 seals they come with.
They are made of viton if I'm not mistaken, so hopefully they would last longer.
Yeah, you can use the seals no problem with the beehives.
Good luck
Old Aug 3, 2011 | 02:53 PM
Tatmonster45's Avatar
go oem
SLVRNBLK
37
Dec 15, 2017 06:30 PM
TurboTylerIX
35
Sep 1, 2016 08:27 AM
sunrichmond
Jan 17, 2011 10:56 AM
CO_VR4
Sep 28, 2008 09:08 AM
