need help drive shaft is making noise
Old Feb 25, 2011 | 06:06 PM
iloveevo's Avatar
I've been hearing a low (clang clang) noise coming from the drive shaft when shifting down or releasing clutch fast sounds like drive shaft noise is it normal? when i lifted the car up i couldn't find anything but i think its the first closest shaft to the trans
Old Feb 25, 2011 | 06:16 PM
mifesto's Avatar
i have this hunch its your rear diff shifting but its common/minor issue. ofcourse i can be wrong as all i got is 3rd hand info.
Old Feb 25, 2011 | 06:24 PM
iloveevo's Avatar
no it sounds like shaft because sound is under shifter
Old Feb 25, 2011 | 06:42 PM
FerdEVO03's Avatar
I had this problem with my evo 8 till i did this:
https://www.evolutionm.net/forums/ev...ur-garage.html
Old Feb 25, 2011 | 07:25 PM
nytalonTSi's Avatar
How are your carrier bearings? Does it do it when you let off the gas too?
Old Mar 5, 2011 | 11:22 AM
An04EVO's Avatar
Might be your transfer case. Ours needs to be replaced and occasionally we hear the sound you describe.
Had it checked out at the dealer and they confirmed its the transfer case.
CMcraz23
Lancer Tranny/Drivetrain Tech
Jul 21, 2016 11:56 AM
EVO9EMC
Apr 1, 2016 08:17 AM
bpdean
19
Dec 29, 2015 03:08 PM
NelloMorto
Dec 20, 2010 02:58 PM
topper_bob
Jul 30, 2008 09:47 AM
