Front parking light fuse??
Old Mar 7, 2011 | 01:48 PM
silverIXMR's Avatar
quick question..can anybody tell me which fuse the front parking lights are associated with? I looked through the manual and it mentions every light except those. I was told they were on the taillight fuses which would make sense however all of my other lights work. Im hoping it isnt the wiring. Any other ideas and info are appreciated. Thanks
Old May 13, 2012 | 08:11 PM
EJEvo's Avatar
I've recently discovered this same issue. Did you ever find a solution?
Old Jul 26, 2013 | 02:26 PM
epiphanysfi's Avatar
Bringing back old thread, Ive been having the same problem to since I got my Evo 8. Any solution that you have found?
Old Jul 26, 2013 | 02:30 PM
EJEvo's Avatar
Here's what I found: both bulbs were burned out and needed to be replaced. Those bulbs are apparently pretty fragile compared to the others. Easiest way to get to them is going behind the front wheel liners. Pretty simple and cheap fix.
Old Aug 1, 2013 | 07:13 AM
So does the light bulb have a secondary on cause my turn signals still work but the fronts don't have parking light ability. Only the rear parking lights turn on.
Old Aug 1, 2013 | 01:25 PM
EJEvo's Avatar
Front turn signals and front parking lights are separate bulbs IIRC, so if the front parking lights are burned out, then it makes sense your turn signals are still working in front. I had the same situation when I replaced mine. Take a look at a replacement bulb in the store to verify that - sorry, it's been awhile since I did it and can't remember the specifics. RockAuto.com says it's a 194NA type press-in bulb for front parking lights.
Old Aug 2, 2013 | 11:50 AM
Thanks man, haven't taken a look at the bulbs yet but went through all of the fuses scratching my head. lol.
Old Aug 2, 2013 | 09:18 PM
silver_ek's Avatar
mine were blown... replaced them... all is good
Old Aug 2, 2013 | 10:04 PM
vicariousthrill's Avatar
same issue here. replaced with new ones and good to go =D
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
Boston'sEvO-->8
May 3, 2021 04:18 PM
jagarcia89
Aug 20, 2014 08:39 AM
DRsnoopy
11
Jan 6, 2013 11:59 PM
malonejr2000
Oct 5, 2009 01:03 PM
