Erratic oil pressure readings with Defi BF
Old Mar 10, 2011 | 02:00 PM
Exciting News's Avatar
I'm getting erratic oil pressure readings with my Defi gauge (needle jumps around, reads zero psi, etc). It generally seems to happen when idling/ in neutral but will act goofy while cruising on occasion as well. I'm not sure if the sensor (plugged into the oil housing) or gauge is causing the issue.
Just wondering if anyone has experienced this before and if it was the gauge or the sensor that was the problem. I'm not even sure how I would test either part except for swapping in known good units (which I don't have lol).
Old Apr 9, 2011 | 03:28 AM
Nicolas's Avatar
Same here. I used to see the needle around 2 at idle and now i have 1.8 or 1.6. I used AMSOIL 15-50 before and now AMSOIL 10-30. I dont think is the oil though.
Old Apr 10, 2011 | 03:14 PM
gymnasty's Avatar
this happened to me as well and by replacing the sender it went away. it could be the oil sender or a bad connection with the wiring.
Old Apr 10, 2011 | 03:31 PM
codgi's Avatar
i'd check the wiring. I had a short once that exhibited similar behaviour
Epyon
Mar 30, 2016 09:36 AM
Jkuti13
Jan 30, 2016 03:35 PM
bboy_RES
28
Dec 11, 2015 05:01 AM
FQ640
Nov 21, 2011 01:49 PM
Kracka
Jul 17, 2009 01:18 PM
