Megan Coilovers Making Noise
Old Mar 21, 2011 | 04:53 PM
tyang85's Avatar
Originally Posted by chu
Sounds like two things:
1. A loose topnut, allowing movements. Try tightening down te topnut.
2. The spherical bearing may be bad, and hence the clunking. I don't believe Megan offers rebuild parts.
I've tighten the topnut like 5 times already. Where is the spherical bearing located? And if they dont make it, does that mean I'm SOL?
Old Mar 21, 2011 | 04:55 PM
tyang85's Avatar
Originally Posted by Solo-Wing06
When I had mine installed the rear would make a similar noise when turning or exiting a dip, after a few days of driving with the setup the noise was gone. Try not to have your ride to lowered I noticed that by adjusting the damper the noise slowy went away.
how low is yours and what is your damper set at? if you dont mine.
Old Mar 21, 2011 | 04:57 PM
tyang85's Avatar
Originally Posted by llDemonll
find someone local with a stock strut or a coilover you can borrow and switch it out (brand doesnt matter, it's a short drive). if it still makes the noise, you know it's not the coilover
I will try that if I find one. If not, maybe I'll get a different set which I dont really want to cause I have other plans.
Old Mar 21, 2011 | 05:03 PM
tyang85's Avatar
Some guy was telling me that it could be the two bushing on the rear lower arm/camber arm. I believe the struts sits on one end and camber bolt on the other.
Old Mar 21, 2011 | 10:13 PM
Solo-Wing06's Avatar
Maybe about half inch lower than stock, got my damper set to 20 out of 32, car feels great not to stiff and not to sloppy.
Old Mar 22, 2011 | 04:36 PM
tyang85's Avatar
anybody?
Old Mar 22, 2011 | 11:02 PM
llDemonll's Avatar
you need to find a stock or another aftermarket coilover/strut and install it in place of the megan one. we are shooting at flies with bullets here trying to solve the issue on your car without being able to drive / look at it.
find a friend or find an evom local member and ask if they have extra parts, people are usually pretty generous in loaning out things for troubleshooting like this
fromWRXtoEVO
33
Feb 25, 2014 03:59 PM
BravoZero
61
Oct 17, 2012 06:20 AM
Positron
Dec 31, 2008 06:27 PM
Silver06evo9mr
48
Sep 1, 2008 11:58 PM
Kurt
78
Nov 30, 2007 08:55 PM
