anyone take apart a engine harness??
Old Mar 22, 2011 | 02:34 PM
  #31
Most Hated's Avatar
i cant wait to start my Wire Tuck. i'm getting anxious just looking at what you guys did.
Old Mar 23, 2011 | 05:48 AM
  #32
Darkn3s's Avatar
Originally Posted by EvoooB
Yes you have to pull the crank pulley and tensioner to fully remove cover. But those two are easy enough to take off.
i took those off but the cover was still on pretty tight so i loosened the idler pulley but couldnt take the bolt completely out because it hit the frame rail but even so the bolt behind the water pump was holding it tight... how do u get around it without removing wp pulley?
Old Mar 23, 2011 | 05:49 AM
  #33
Darkn3s's Avatar
oh yes it will be fun!
Old Mar 23, 2011 | 06:32 AM
  #34
EvoooB's Avatar
I'm trying to remember but it's been awhile since I've done it. I'm going to have to look at the car when I get home. I do know that I had taken everything off in that area anyways, because of the 60k service.
Old Mar 23, 2011 | 09:18 AM
  #35
tkklemann's Avatar
The idler pulley should come off, you won't be able to get it off with a socket and ratchet, you will have to use a wrench. It should definately come out, unless someone put in a longer bolt then put the motor in the car. The factory bolt just barely squeeks out of there, but it will come out.
The water pump pulley does have to come off to be able to get to a timing cover bolt behind it unfortunately.
Old Mar 23, 2011 | 09:20 AM
  #36
tkklemann's Avatar
so the 05 harness cant be used for the 03 minus a couple of sensors?
Don't know if I can answer that one. What I will tell you is that if you find you can't use it, let me know and for the price you paid for it, I will take it off your hands. (Assuming you win/won the auction)
I would love to make a new harness OFF the car.. The key is OFF the car.
Old Mar 23, 2011 | 09:41 AM
  #37
Darkn3s's Avatar
yea i cant loosen bolts on wp pulley since it spins the pulley when i try to loosen each bolt.. and its a good 6 bolts smh.. but yea the idler pulley bolt wont come out its maybe a inch off.. sucks
yea ill let you know the action should be over soon but yeh this should be fun!
Old Mar 23, 2011 | 01:35 PM
  #38
Darkn3s's Avatar
does anyone know if i have to drop the motor some from pass mount?
Old Mar 24, 2011 | 06:24 AM
  #39
tkklemann's Avatar
You can do it, you just have to find a way to keep the pulley from spinning. I use either two things, my hand wedged down in there, or the end of a hammer I have that has a rubber handle. It sucks, and this is the reason I try to find ways to avoid taking it off. It's just one of those things that sucks.
Did you actually win the auction?
And I sent you a text this morning too...
Old Mar 24, 2011 | 06:27 AM
  #40
tkklemann's Avatar
If you can't find a way to stop the pulley from spinning, most people remove the passenger side motor mount to be able to get more room to stick your hand down in there..
Old Mar 25, 2011 | 09:30 AM
  #41
Darkn3s's Avatar
update: i was able to replace the crank sensor with a new one but of course... it still didnt start
i didnt win the auction to the harness.. will have to try and find another either on here or the forums
anyone willing to donate???
Old Mar 25, 2011 | 09:32 AM
  #42
Darkn3s's Avatar
-crank sensor replaced with NEW
-cam sensor replaced with NEW
-new spark plugs gapped at .024
-checked all fuses inside and out the car ALL GOOD
-put a buddies working spark tech COP still wouldnt start
Old Apr 6, 2011 | 07:43 AM
  #43
Darkn3s's Avatar
update:
turns out my car started up and i didnt end up having a faulty harness so dont really need to redo my engine harness just yet.. still need to break in my motor so dont want any down time
if anyone is interested...
i ended up recieving the engine harness i got from ebay but it turns out to be the harness that runs from the interior fuse box connectors out to the engine bay fuse box (included) then to the rest of the headlight, fan, radiator, airbags, ac connections etc.. basically everything up front
Darkn3s
May 17, 2018 08:58 AM
xgamer
Sep 17, 2015 09:13 AM
High_PSI
May 20, 2015 09:45 AM
Darkn3s
Jan 25, 2011 12:21 PM
nexgen
May 28, 2010 05:58 AM
