how to remove CEL..
Old Mar 29, 2011 | 07:15 PM
ron2003's Avatar
how to remove CEL..
Ignore the title
HOW TO DELETE the CEL without using a OBD2
thanks
Old Mar 29, 2011 | 07:17 PM
SRT4101's Avatar
Fix source of light and or pull battery terminal in a pinch lol
Old Mar 29, 2011 | 08:10 PM
MRolla's Avatar
Take the bulb out the dash. Fix the problem and then clear it by disconnect the battery or the fuse for the ecu
Old Mar 29, 2011 | 08:29 PM
Hitmachine101's Avatar
disconnect the battery, the car will likely have to go through a few engine cycles and diagnosis before it will come back on again. If you know the issue causing the light then simply fix it
If your trying to get the car to pass inspection then pulling the light in the dash wont get it done, lol ive tried that
Old Mar 29, 2011 | 08:40 PM
chaotichoax's Avatar
Originally Posted by ron2003
Ignore the title
thanks
why?
no matter how you slice it you aren't deleting it without the obd-II port
Old Mar 30, 2011 | 08:44 PM
boostedmkiii's Avatar
Originally Posted by chaotichoax
why?
Right. Plus, if all you are trying to do is clear an engine/CEL code, it is SO easy. Much easier than pulling the bulb or disconnecting the battery for a while.
Advance Auto and AutoZone can help you out with this for FREE.
As stated before, the best way to get rid of it is to fix the cause of it being on...
Old Mar 31, 2011 | 05:57 AM
the obd2 scanner is free for use at autozone/advanced auto, and you can buy it if you want for i think 70 dollars, best way to go after a CEL is with this tool, get the code and post it up here, well help you diagniose the issue
Old Mar 31, 2011 | 07:35 AM
SmurfZilla's Avatar
get a tactrix cable and scantech app and clear
Old Mar 31, 2011 | 04:08 PM
01 Trans-Am WS6's Avatar
Disconnect battery for 15 mins then reconnect and BAM no light!
Domengg Domino
Dec 3, 2016 07:06 PM
SPOOLIGAN
Sep 8, 2016 12:07 PM
The hundreds.
Jul 26, 2008 07:39 PM
Silverfox742
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 12, 2008 10:28 AM
supersupra
11
Sep 12, 2006 08:08 PM
