About to bake the headlights but unsure if I removed everything
Old Apr 1, 2011 | 01:25 PM
dtrackstar's Avatar
I read the DIY write up, but I am not sure if I took everything required out. I have pics. If you have done this, please let me know if anything else needs to be removed before putting them in the oven.
Thank you,
Demetri
Old Apr 1, 2011 | 02:18 PM
brand0n's Avatar
Can u removed that plug in the middle on your picture 3? If not, then it looks to me like your good to go! GoOD LUCK!
picks after!
Old Apr 1, 2011 | 02:22 PM
tim85851's Avatar
no need to bake man...i did my headlights...i used a blow dryer...take your time...use the blow dryer and a flat head screwdriver...good luck.
twabtoxer's Avatar
for me using a heat gun was better since you can control it better . point and shoot..... but in your case everything looks ready to go in the oven good luck
Old Apr 1, 2011 | 02:23 PM
dtrackstar's Avatar
The 2 clear ones?
If you're referring to the darker l shaped plug (i think). I removed it after taking the pic. There were 3 actually in total
wizzo 8's Avatar
Might want to take those rubber vent tubes off.
dtrackstar's Avatar
how long did it take you with the blow dryer?
Old Apr 1, 2011 | 02:25 PM
dtrackstar's Avatar
Yah I just did. there are 3. thanks!
Old Apr 1, 2011 | 02:27 PM
tim85851's Avatar
took less that 10 minutes to take the cover off with the blow dryer...
Old Apr 1, 2011 | 02:30 PM
tim85851's Avatar
what i did was: blow dried the edge where the glue is...heated up the whole border...then start at one corner...(its good to have a friend holding the blow dryer)...have them point it where you're prying...id recommend gloves...it gets a lil hot...lol...
the reason i did it with my blow dryer is because i didnt want to risk over baking my headlights or just something going wrong...
hope you try it this way first...it'll work!
Old Apr 1, 2011 | 02:53 PM
dtrackstar's Avatar
When I'm prying I im bending the black plastic? is that normal
dtrackstar
Nov 3, 2011 09:51 AM
dtrackstar
For Sale - Wheels / Tires
Jun 26, 2011 10:12 AM
dtrackstar
For Sale - Cars For Sale
Jan 18, 2011 11:40 PM
dtrackstar
Jan 28, 2010 06:32 PM
