Back of intake manifold boost leak.
Old Apr 18, 2011 | 12:46 AM
Foxmaster's Avatar
I was doing a boost leak test and right around 25 psi I get a leak coming out of this thing (center hole) from the back of the intake manifold. What is it? Is there a replacement/fix someone can guide me too?
Attached Thumbnails Back of intake manifold boost leak.-boost-leak-issue.jpg
Old Apr 18, 2011 | 02:49 AM
ddb's Avatar
ddb
There you go https://www.evolutionm.net/forums/ev...leak-help.html
Old Apr 18, 2011 | 06:31 PM
warstang27's Avatar
its part of the throttle body and the orings go bad on these things all the time mine did. you can replace the oring, or if you want the evo IXs dont even have that port so its obv not gonna leak
Edit: i really hope you didnt take the intake manifold off just to show us that lol
Old Apr 18, 2011 | 09:17 PM
10isace's Avatar
I wouldn't say it's funny, but I just took pics of mine when I did a boost leak test tonight and was about to post it on here. Thanks for posting, because your pic is way better than mine!
I found the part at works or MAPerformance.
Looks like we're in the same boat!
Old Apr 19, 2011 | 12:48 PM
Foxmaster's Avatar
I just pulled mine out, o ring looks fine, but I will replace.
Does anyone know where the half moon pieces go on the shaft, mine kind of fell apart when I took it out.
I found intake manifold pic on the net, this part is pretty easy to get to.
Old Apr 19, 2011 | 05:16 PM
Foxmaster's Avatar
I couldn't find any diagrams in the service manual so I ended up putting the half moon pieces together in the middle of the shaft.
Old Apr 19, 2011 | 05:28 PM
gieri002's Avatar
I threw some liquid gasket on mine rather than replacing the o-ring and my boost leak has been gone ever since!
Old Apr 12, 2012 | 09:15 PM
Howulikemyevo's Avatar
One of my vacuum line on the throttle body and my intake manifold is not where it supposed to be. It just hanging behind the intake manifold. I can't see where it suppose to be plug into. Can someone take a pic of ur whole intake manifold so I can see where my hose suppose to be in? Pm me. Thanks
Old Apr 13, 2012 | 03:22 AM
bigben's Avatar
Possibly the one that goes to the EGR valve?
1Ferrari
14
Feb 5, 2012 09:40 AM
kmcconn9
24
Oct 5, 2009 03:43 PM
sslevo
12
May 10, 2009 09:50 PM
Done
20
Jun 11, 2008 10:50 AM
CrackerJackToy
Nov 21, 2007 09:36 AM
