Very weird idle! (with video) PLEASE HELP!!!
Old Aug 30, 2011 | 05:00 PM
  #136
dac001's Avatar
Thumbs up
thsx C130flyer your looping the vaclines WORKED for me...... {thum bup}
Originally Posted by C130flyer
Well I am very pleased to tell everyone on this thread that after forever I finally fixed it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
I deleted the EGR vacuum lines by looping the 2 vac lines on the top of the throttle body back into each other and presto fixed yeah!
Must have been the egr solenoid or associated vac lines leaking lol.
Old Sep 1, 2011 | 06:56 AM
  #137
Jimbolution's Avatar
do you have a pic of you repair ? to see how you loop them ?
Old Sep 4, 2011 | 01:56 PM
  #138
BBY_GSR's Avatar
I, too, need some pictures, please!
Old Sep 6, 2011 | 06:12 AM
  #139
C130flyer's Avatar
Old Sep 7, 2011 | 12:51 PM
  #140
19.5PSI's Avatar
were there any check engine light after the delete? would there be a problem with the state inspection?
Old Sep 7, 2011 | 09:47 PM
  #141
BBY_GSR's Avatar
C130flyer, thanks!!
19.5PSI, I'm from California and until it is time to run my car through the sniffer test, I'll go with this method. I will have to find the root cause of this loping issue though.
Old Sep 8, 2011 | 07:18 AM
  #142
C130flyer's Avatar
I think that the root cause is the EGR activation solenoid on the back of the intake
Old Sep 8, 2011 | 05:33 PM
  #143
BBY_GSR's Avatar
I'll have to check out the solenoid.
The looping of the two vacuum lines did not do the trick for me.
http://youtu.be/ae6wph8uaQQ
Old Sep 9, 2011 | 05:24 AM
  #144
found it me too it was the timing belt.... so what i can say is : get out the cover and check if the guide are align :P
Old Sep 9, 2011 | 01:37 PM
  #145
C130flyer's Avatar
You for sure have a vacuum leak I watched your video.
I just ordered a smoking vacuum leak tester it was like 900 bucks.
When it gets here I will test it out and try to find where this issue may be coming from.
I feel like its time for someone to step up and figure this out for everyone.
I AM ON IT BRO"S
Old Sep 10, 2011 | 02:36 AM
  #146
rio-evo's Avatar
I had to replace the air fuel servo and clean out the EGR. Now the car idles perfect.
also pure degreaser works best for cleaning.
Old Sep 11, 2011 | 01:29 AM
  #147
BBY_GSR's Avatar
I AM ON IT BRO"S
Holy crap! Thanks for stepping up. I was thinking about sending in my car to a shop to have a mechanic figure the issue out, but I'll wait.
Good luck!
Old Sep 25, 2011 | 06:58 PM
  #148
rhd-jon's Avatar
i have the same problem now
Old Oct 18, 2011 | 05:21 PM
  #149
19.5PSI's Avatar
any update on this?
finally had the chance to fix my other problems on the evo and haven't had a chance to check the bad idle.
Old Oct 19, 2011 | 01:33 PM
  #150
EVO8STI's Avatar
im gonna try the looping and see if that fixes my problem
