Lost boost
Old May 5, 2011 | 01:13 PM
mitsuclipsegsx's Avatar
Lost boost
Recently i installed some new mods, before i did i had 3in tbe, intake cone and ams tune at 23psi. I added ets fmic with pipes, jmf intake pipe, ported manifold and turbo and 02 dump. and im only getting 20psi?? whats the deal. i did a smoke test and no leaks?!?
thanks
Old May 5, 2011 | 01:16 PM
evo8426's Avatar
turn the boost back up, you did add a bigger intercooler
Old May 5, 2011 | 01:25 PM
Sacevo9mr's Avatar
re-tune for sure.
Old May 5, 2011 | 01:30 PM
4RETECH's Avatar
The volume of air is different. You will loose boost pressure by adding that stuff for the volume the turbo has to fill.
You did a boost leak, or did you smoke test with 26psi??
I have an appointment the 21st of this month for the tune. I dont have a mbc yet, it was set thru the flash i guess.... thanks guys!
Old May 5, 2011 | 01:31 PM
My buddy took my car to work( audi dealer) and did the smoke test but only 15psi he said, thats all it went up too...
Old May 9, 2011 | 02:05 PM
turboback1243's Avatar
do a boob leak test..you can make one from lowes for like 10 dollars
Old May 9, 2011 | 07:21 PM
didnt know you can get ***** for $10
Old May 9, 2011 | 09:02 PM
chaotichoax's Avatar
lmfao
yes a "boob" leak test is your best better for sure but as the others have stated you added more volume for the turbo to fill which equates to a boost pressure drop
oscarquinones
Oct 26, 2014 06:57 PM
ghad
May 25, 2014 02:27 AM
abosoxfan4life
Cobb AccessPORT
12
Mar 26, 2013 09:56 AM
dambikeracer
39
Apr 19, 2010 09:46 PM
landis507
11
Oct 29, 2008 08:46 PM
