Man.. Boost leak? or normal. Vid inside
Old May 14, 2011 | 01:13 PM
k20toEVO's Avatar
Question Man.. Boost leak? or normal. Vid inside
So this is a pull I did out at the track and just watch the gauges. Goes 26 to like 18psi.
I did a boost leak but couldn't find anything, why isn't it holding close to 26 psi? Its a evo 9 turbo.
http://www.youtube.com/watch?v=K8hN9VhXqaM
Im #523
Old May 14, 2011 | 01:23 PM
erald01's Avatar
def a boost leak, did you do the test properly??
Old May 14, 2011 | 02:18 PM
k20toEVO's Avatar
Could the wastegate be going bad?
Found the how to under the first link lol..
https://www.evolutionm.net/forums/ev...g-how-why.html
Old May 28, 2011 | 01:22 PM
k20toEVO's Avatar
Ug I think its just a weak wastegate? :| upgrade to the 25 and see if it stops? lol
Old May 28, 2011 | 01:29 PM
BLKCarbonEVO's Avatar
Ya man, it is the wastegate most likely. Remember the stock IX turbo won't hold 26psi out the top but should be able to hold 22+. Throw a 25psi wastegate on there, but don't pre-load it to much or you will get bad overboost.
Mikey
Old May 28, 2011 | 04:16 PM
Nashou66's Avatar
Why not try to pre load your current WG a little more if it has adjustment room to see if it holds any better.
There was also a post somewhere where a guy used springs to help get more holding pressure from the stock waste gate. it went from the rod connection point to the flange of the WG body.
I think the stock waste gate is only rated at 11psi.
Athanasios
Old May 28, 2011 | 04:25 PM
rileyschroeder's Avatar
im going to be trying a 25 psi wastegate. that would probably take care of the problem
Old May 29, 2011 | 12:46 PM
k20toEVO's Avatar
Athanasios
I have a 18psi FP wga. loaded all the way. not helping
Old May 29, 2011 | 12:52 PM
Take the turn buckle off, remove the nutt, and cut three threads off and then you will have plenty of preload. That is what I did.
Mikey
