Emissions wont pass
Old May 14, 2011 | 09:58 PM
chubbs203x's Avatar
Emissions wont pass
so i went to do Emissions and it didnt pass, the code po125:insufficient coolant temperature for closed loop fuel control came up can somebody help me out and tell me what i can do to fix this problem it or what might be causing it thanks.
Old May 16, 2011 | 09:29 AM
X91EVO's Avatar
Registered User
disconnect your rad fan, and keep your heat off.
thats crazy we dont have to deal with strict emissions like that in IL!
Old May 16, 2011 | 09:38 AM
TJPhillips36's Avatar
Could be possible that your coolant temp sensor is bad. If not then the car just needs to be ran hot, it sounds like it's begging for a track day!
Old May 16, 2011 | 12:03 PM
GrandmasterCow's Avatar
change coolant and drive car for a bit, reset that code.
Old May 16, 2011 | 12:08 PM
gsrboi80's Avatar
Prior to this was any tuning done on your car there is a table for just this in the ECU that I have seen some tuners try to adjust to combat idling issues.
If that value is changed you'll get that code?
Old May 16, 2011 | 12:30 PM
SmurfZilla's Avatar
Did you go to the emissions test with your SES/CEL on? If thats the case then of course you were going ot fail. If it happened while they had the computer hooked up to your ECU then that's a little suspect.
Old May 16, 2011 | 08:11 PM
gby2k6's Avatar
I ran this through a buddy who's a smog tech and he said more than likely you'll need to replace the thermostat.
Old May 17, 2011 | 09:05 AM
barneyb's Avatar
^^^Yeah, first change the thermostat and then, if that doesn't fix it, the temperature sensor.
Old May 17, 2011 | 11:25 AM
prs0303's Avatar
PA is the same way. Car won't pass with the CEL on regardless of the code.
Just go along with what these guys said, Replace the Therostat and the CTS. They're both cheap enough and easy enough to get to that you'll spend more money trying to snake your way around the emissions test...
Old May 30, 2011 | 03:01 PM
chubbs203x's Avatar
thanks for the help guys
Old May 30, 2011 | 03:58 PM
boczo777's Avatar
get tephra and f%&k emissions....
Old May 30, 2011 | 06:38 PM
SmurfZilla's Avatar
Lol. +1
DeliriouS
Jul 1, 2025 08:25 PM
CJK
34
Apr 1, 2017 05:24 PM
boostin@27
Oct 16, 2007 10:47 PM
initialDRacer
Mid-Atlantic Region
Apr 22, 2005 05:13 PM
