Knocking sound top mount front suspension
Old May 16, 2011 | 09:45 PM
iceberg51's Avatar
Hi guys,
I need everyone's help, I had Bilstein Ralliart coilover suspension mounted on my EVO 8 GSR, I am puzzled that there is a knockking sound the comes at the top mount of the shocks. I have tighten the bolts on the top mount and it seems to be tight and took the car fora spin and yet the knocking sound is still there. The sound came when driving on uneven surface but on the highways it seems to be alright. Can anyone help me to solve this issue.
Old May 16, 2011 | 10:03 PM
iceberg51's Avatar
anyone
Old May 16, 2011 | 10:52 PM
llDemonll's Avatar
sounds like a blown shock
Old May 16, 2011 | 11:22 PM
iceberg51's Avatar
OMG this sounds serious
Old May 17, 2011 | 03:08 AM
boostx's Avatar
Have you check your strut mount and the bump stop. How much miles on the shocks?
Old May 17, 2011 | 01:08 PM
reboundicon's Avatar
Are you driving it at extremely cold temps? Coilovers are notorious for making clunking sounds when it is cold out or below 0 outside. Let the car warm up or park it indoors for a while and see if the problem still exists. Unless the shock is leaking, it shouldn't be blown.
Old May 17, 2011 | 07:09 PM
iceberg51's Avatar
Yup I did remove and install back the assembly it seems to be fine, it was 26k as per current. BTW the strut mount was the upper mount rite? were is the bump stop anyway? if any figure diagram will be more help full...
Old May 17, 2011 | 07:14 PM
iceberg51's Avatar
Nope I live at a tropical climate, and I did remove it to check any defects but there were no leak, the knocking sound seems to be some were around the top of the shock mount only at some rough surface but on a smooth roads it does not make any sound. If the shock is blown it will make knocking sound on smooth and rough surface.. hope any one can help me on my issues....thanks
Old May 18, 2011 | 09:47 AM
Tfresh's Avatar
Im having a similar issue I get a clunk on bumps sometimes and it sounds like its coming from the top of the strut area but it only does it sometimes. One day its clunking and the next day its fine
Old May 18, 2011 | 09:55 AM
MrDgaf's Avatar
Welcome to the world of coilovers. Like stated above ALOT of coils make clunking noises. Even brand new ones from my experience. Rent a wireless db reader, attach the sound magnets ALL OVER the coil over, put the headphones on and make it happen. That will narrow it down within an inch or so. I use em at the dealership i work at to find them pesky noises/ vibrations. Good Luck!!
Old May 18, 2011 | 06:44 PM
iceberg51's Avatar
so its normal for coilover suspension systems, here's what I have done, remove the suspension assembly cleaned it check for potential leak, and assemble back again and tighten the bolts for top mount, FYI the top mount is still using the stock top mounts. After a few days after tightening then one the noise came. so any tots of this issue
Old May 27, 2012 | 02:02 AM
elim0's Avatar
Hi, I see this post is from last year but I am new to the forum and was looking up this issue as I have it with my evo8. I also have bilstein coilovers and this sounds like the excat same problem im having. the knocking is happening from the front left, it comes and goes. i went to get it checked out, paid for them to inspect, service, clean, the front struts/shocks and they said it was all good now.. the knocking went away for 2days but is back now. anyone with new information would be much appreciated ! thanks !
elim0
Nov 14, 2020 01:55 AM
killerpenguin21
Jan 9, 2017 08:38 AM
lousEVOxmr
25
Dec 22, 2015 10:09 AM
timasse
Jan 10, 2014 08:22 AM
skforty
Aug 25, 2011 02:00 PM
