How to Properly Care for your FP Turbo, Info From Robert at FP
Old Dec 29, 2011 | 04:41 PM
  #46
wizzo 8's Avatar
I sent in an Evo 9 turbo to get converted to a black. I never got a warranty card nor did I get a plaque on the turbo. I called and they said they would sent me one. Never got one. 1yr is over now so I guess it doesn't matter.
Old Dec 31, 2011 | 04:17 AM
  #47
Kins's Avatar
Good post - thanks for sharing High PSI.
Old Dec 31, 2011 | 04:29 AM
  #48
Kins's Avatar
Originally Posted by BLKCarbonEVO
The main thing is the right oil, Kiggly HLA, and BR oil pan mod or AMS oil pan and you will NEVER have a problem!
Mikey
That is a bold statement indeed Mikey and one I have to disagree with! It totally depends on the application - Fitting a Kiggly HLA and BR/AMS sump will not make you invincible! How many Time Attack cars do you know that use just a Kiggly HLA and BR/AMS sump?
I happen to sit on the same side of the fence as Si Norris. This quote was lifted from his advert for the Norris Designs dry sump kit.
These are totally ESSENTIAL on anything running good tyres and has 1G or more through right hand bends. The way to justify this to yourself is..........."Do you want to buy the dry sump kit now while your engine is healthy, or have to pay for a new engine and a dry sump kit later?" It really is that simple, there is NO WAY of solving the evo 4-9 right hand oil surge issue without a dry sump. We have tried every option from the simple to ridiculous, nothing else works!
http://www.lancerregister.com/showthread.php?t=333816
Old Feb 3, 2012 | 09:03 AM
  #49
udluz's Avatar
I can tell this evo forum is going to be very helpful!!
Old Mar 11, 2012 | 08:34 PM
  #50
Howulikemyevo's Avatar
does the fp turbo brake easy? i have read that the jb fp turbo brake easy
Old Mar 12, 2012 | 04:53 AM
  #51
wizzo 8's Avatar
I normally use the car brakes to slow down. Didn't know turbos can brake a car now?? Oh maybe you meant break? Well as long as you follow Fp oil recommendations they are ok. The new bb version will probably last a very long time though.
Old Mar 12, 2012 | 05:19 AM
  #52
todd6027's Avatar
nope
Old Mar 12, 2012 | 09:57 AM
  #53
wizzo 8's Avatar
Originally Posted by todd6027
nope
What nope? For the most part they are good reliable turbos. I haven't had any problems. I follow fps recommendations. I don't run more boost than it was designed for. All is good. When people don't follow the recommendations problems arise earlier. You can't say oh you have an Fp turbo and its going to fail. Most all turbos eventually fail. Yes some sooner than others. Just a matter of how you treat it. Just ask sharkbite how many turbos he went through.
Old Mar 12, 2012 | 10:02 AM
  #54
binky's Avatar
True story.com
-Bink
Old Mar 12, 2012 | 11:45 AM
  #55
kyoo's Avatar
i've got the turbo, probably gonna get the hla, considering at least BR's oil pan mod.. hopefully things work out well
Old Mar 12, 2012 | 02:31 PM
  #56
todd6027's Avatar
follow guidelines or not they still fail prematurely under NORMAL operating conditions
Old Mar 12, 2012 | 04:47 PM
  #57
wizzo 8's Avatar
Well they converted to ball bearing so "problem" solved
Old Mar 13, 2012 | 10:21 AM
  #58
todd6027's Avatar
not for those who bought jb
Old Mar 13, 2012 | 10:50 AM
  #59
wizzo 8's Avatar
I have a jb black. I'm not to worried
Old Mar 13, 2012 | 02:09 PM
  #60
todd6027's Avatar
