clutch pedal acting odd
Old Jun 27, 2011 | 07:26 PM
Yoshi W's Avatar
Hi, so I've been drivin my 2005 evo 8 alot, it has 74,500 miles and running well, except im worried about the clutch. Recently, when I push in the clutch pedal it seems easier than before, and it engages way too easy, way easier than before, to the point its vague when the clutch engages. However, the clutch isnt slipping, but the evo does feel like it is lacking some power in the lower revs, any ideas whats going on?? Thank you.
Old Jun 27, 2011 | 09:42 PM
Jerry321's Avatar
Check your fluid level, look for possible leaks.
Old Jun 28, 2011 | 04:51 AM
Yoshi W's Avatar
the fluid level is normal, thanks for the suggestion though. Any other ideas? this is really making me worried cause I'm afraid I'm gonna make the problem worse if I drive it.
Old Jun 28, 2011 | 04:55 AM
fugiwara's Avatar
still on original clutch? have you launch this car before?
Yoshi W's Avatar
Also it still changes gear normally, and the clutch pedal still comes back up, just the engagement point is extremely vague compared to a few days ago.
Old Jun 28, 2011 | 04:56 AM
Yoshi W's Avatar
It is the original clutch as far as I know, and its only been launched once almost two years ago since i have owned it.
Old Jun 28, 2011 | 11:25 AM
spooldursti's Avatar
maybe its just time for a new clutch. if your fluid level is fine, and the pedal returns, and there's no problems getting it in/out of gear, sounds like the clutch is just worn out.
Old Jun 30, 2011 | 05:00 AM
Yoshi W's Avatar
brought it to a mechanic and it seems like it probably is the clutch, i was hoping it wasnt but oh well, thanks for all the help!
Old Jun 30, 2011 | 05:21 AM
warp9's Avatar
Dude try adjusting it so it grabs where you like it. That should help
Old Jun 30, 2011 | 05:32 AM
laxplayer14's Avatar
idt adjusting it is gonna help since its hydraulic meaning it self adjusts as the clutch gets thinner and thinner. a new clutch should def take care of it for u
Old Jul 2, 2011 | 05:33 AM
Yoshi W's Avatar
yup, new clutch solved it, muuch better. I think the previous owner burned out the clutch and according to the mechanic partially the flywheel too cause since i've owned the car its never felt this grabby with the clutch before. Thanks for all the help and suggestions!
Old Jul 2, 2011 | 12:46 PM
bigben's Avatar
I would've made sure it wasn't the master or slave cylinders first. Much cheaper than a new clutch, if that's what the problem was. Normally when a clutch goes bad, it just slips. If the pedal pressure changes, then one or both of the clutch cylinders are to blame.
Old Jul 2, 2011 | 02:25 PM
DEVIL EVO IX's Avatar
Hey, did you figure out what the problem was.
Old Jul 2, 2011 | 02:45 PM
nytalonTSi's Avatar
New clutch he said.
Old Jul 3, 2011 | 07:24 AM
Yoshi W's Avatar
yea, new clutch solved my problem, but it is ridiculously expensive, since we have awd and a smaller car it is more work and greatly raises the cost, I would definitely check the slaves next time or any cheaper solution first should this happen again. Thanks!
Kris86
Oct 5, 2016 10:31 AM
Uscbryan
Jun 7, 2014 08:46 PM
cmross13
May 30, 2013 07:43 AM
rsboy
24
Jun 14, 2007 12:35 PM
trinydex
Mar 29, 2007 05:40 PM
