Probe for EGT on downpipe...
Old Jun 28, 2011 | 08:06 PM
black_beauty's Avatar
My cars downpipe was tapped for an EGT gauge when I bought it with a Greddy gauge but the gauge crapped out. Now I want to get a Prosport EGT gauge and use the same tap, I doubt it will be that same but I was wondering if there is some kind of adapter I can get to make it work in the same hole. Thanks
Old Jun 29, 2011 | 08:27 AM
Iowa999's Avatar
Out of curiosity, why isn't it in the exhaust runner for cyl 1 or 2? Why do you want to know the temp post-turbo?
Old Jun 29, 2011 | 08:39 AM
I have no clue, thats where it was when I bought it. I take it thats not a good spot?
Old Jun 29, 2011 | 08:54 AM
Iowa999's Avatar
The standard location is in the runner from the cyl that is furthest along the fuel rail (and, therefore, most likely to run lean first). The exception is when a different cyl is known to run hottest (e.g., cyl 2 usually runs hottest on a 4g63; no idea about 4b11, but you have a 4g63, right?). You want the probe about 6" from the exhaust port, so maybe 4" or 5" down the runner. After the turbo can be highly misleading due to the drop in energy as the pressure drops. In more ways than one, post turbo is too late to save you. My guess is that the extra bung in the downpipe was meant for a wideband.
Old Jun 29, 2011 | 09:06 AM
Its wayyy to small for and o2 bung, idk i guess ill just plug it then
Old Jun 29, 2011 | 09:13 AM
thepoint4life23's Avatar
and from what i have been told egt is kinda of old school gague. not needed as much any more . but i could be wrong
Old Jun 29, 2011 | 09:17 AM
Raptord's Avatar
As said by others, after the turbo is way too far for an EGT probe. Mine is a couple inches down the exhaust runner (#2 cyl. if I'm not mistaken).
It's not as important as a wideband but it can be handy if you want to tune leaner while making sure your EGT's are in check. (running leaner during cruise for example). Since I have it I also want to gather some data of running 11 AFR vs 11.5, etc, and seeing what the difference in EGT really is.
Old Jan 10, 2012 | 01:20 PM
10isace's Avatar
Sorry for the Resurrection of this thread, but did you end up getting the Prosport EGT and did you install it on #1 or #2?
Jovan Caro
Feb 22, 2017 11:04 AM
hempele28
Aug 15, 2009 08:56 PM
amg destroyer
Mar 26, 2008 09:49 PM
SlowCar
Dec 3, 2006 09:22 PM
Dave2
18
Oct 3, 2004 04:23 AM
