Quick Boosting Question
Old Jul 2, 2011 | 10:12 AM
toyotabike's Avatar
Do I NEED to have a booster controller to change the boost setting, or can a tuner change it through a reflash?
Old Jul 2, 2011 | 02:29 PM
JDMCT9MR's Avatar
There are a number of options to control boost. You can have a manual,electronic,a 3 port boost solenoid, an open ECU tune with the boost dialed in. You can also run one of the boost control options listed above in conjunction with a open ecu tune and get great results. It all depends on what you are looking for. I highly recommend getting your car tuned if you are turning up the boost. Also remember that as you add mods your car will gradually boost a little more here and there. Hope this helps!
Old Jul 2, 2011 | 03:17 PM
Raptord's Avatar
The car isn't really capable of reaching higher boost levels as-is from the factory. You can change the restrictor pill in the vac. line going to the BCS to give you some more headroom, but your best option IMO is a 3-port solenoid like the grimmspeed which can then be controlled through the ECU.
jrmav32
Jul 3, 2017 11:44 AM
mrdecrypter
14
Apr 8, 2009 02:42 PM
raidokoiv
Apr 13, 2008 10:58 PM
EvoJoeIX
May 14, 2007 07:30 AM
evo4.5
Nov 24, 2003 07:39 PM
