hallman boost controller issues
Old Jul 2, 2011 | 11:06 AM
chris89's Avatar
I have a evo 9 I have just installed a hallman boost controller I capped both holes on the boost selonoid the one on the intake and the turbo. I ran a vaccum line from wastegate to the boost controller and I teed the bov and ran it to the bc. Im only hitting 10psi I'm sure I did the install correct can anyone help? Thanks
Old Jul 2, 2011 | 11:28 AM
chris89's Avatar
Anyone? I tried searching but nothin
Old Jul 2, 2011 | 11:41 AM
chinto's Avatar
try this link
https://www.evolutionm.net/forums/ev...vo-rx-pro.html
Old Jul 2, 2011 | 01:34 PM
chaotichoax's Avatar
the link chinto provided should definitely help
Old Jul 2, 2011 | 01:39 PM
chinto's Avatar
if you keep having issues chat back and i can try to help more or possably meet up with you.
Old Jul 2, 2011 | 02:23 PM
DEVIL EVO IX's Avatar
@chinto nice link.
Old Jul 2, 2011 | 02:30 PM
chinto's Avatar
Originally Posted by DEVIL EVO IX
@chinto nice link.
thanks i didnt make it wish i did. but it was helpfull so i book marked it.
good how to's are hard to find
Old Jul 2, 2011 | 03:26 PM
chris89's Avatar
Well I got it to boost over 10psi but when I turn the boost even like up to 15 it just doesn't feel like it its weird it feels slow it doesn't pull at all
Old Jul 3, 2011 | 04:12 AM
chris89's Avatar
Any suggestions?
Old Jul 3, 2011 | 04:15 AM
HaVoC187's Avatar
Did you already do a boost leak test?
Old Jul 3, 2011 | 09:37 AM
chris89's Avatar
I haven't done that yet.. maybe I have something backwards idk but i double checked it
Old Jul 3, 2011 | 09:54 AM
chinto's Avatar
try to do a boost leak test. make sure every thing is tight. tripple check how the boost controler is hooked up.
how much boost were you making before you tryed to hook up the controler?
do you have any other mods done to the car?
Old Jul 3, 2011 | 10:01 AM
chinto's Avatar
also which way did you hook it up did you T into the bov line or did you go from wastegate to turbo?
Old Jul 3, 2011 | 10:12 AM
EmeryatSTM's Avatar
Turn it up past 15 psi. That is a lot less than stock.
-Em
Old Jul 3, 2011 | 10:32 AM
chinto's Avatar
i may have miss read.
-EM is correct turn boost up more. stock is 19 - 20 psi
if its not going over 15psi then there is another issue. and try what i said.
