evo 8 electrical problem
Old Jul 8, 2011 | 12:11 PM
xRoguex's Avatar
Symptoms -- Injector 3 just sprays constantly.
P0203, P0340, and P0335 -- Injector3, cam and crank sensors. All pretty much came on at the same time.
Checked the WHOLE god damn harness. Found no broken wires.
Injectors sent out and checked by ID -- found nothing wrong but cleaned them anyways.
Swapped ecu's out - still no change.
Swapped out cam sensor -- still no change.
Pulled off timing belt -- crank sensor "looks" fine.
....wtf....
I ohm'd the crank sensor of 3 other running evos and came back with 15.1-15.8ohms. Then i ohm'd mine -- I came up with 19.9. My cam sensor ohm'd out the same as the other evos.
Does anyone know the sensor range for the crank sensor? Any other ideas here?
Old Jul 8, 2011 | 12:28 PM
gsrboi80's Avatar
Injectors sent out and checked by ID -- found nothing wrong but replaced them anyways.
....wtf....
According to FSM
Crank Position Sensor
Engine: cranking 0.4 − 4.0 V
Engine: idling 1.5 − 2.5 V
Don't see a resistance noted
Old Jul 8, 2011 | 12:35 PM
xRoguex's Avatar
Thats the problem -- Idling is nearly impossible. Plus all that fuel will ruin rings etc.
Old Jul 8, 2011 | 12:43 PM
gsrboi80's Avatar
For S&G's have you tried another crank sensor. I know it's a PITA just to "TRY" but certainly your narrowing things down at this point.
Most times I've seen it'll throw the CEL for both crank and cam angle sensors if there is an issue
Old Jul 8, 2011 | 12:57 PM
xRoguex's Avatar
IM thinking im just going to have to get one and go for it..
Old Jul 10, 2011 | 02:03 PM
xRoguex's Avatar
anyone else got any ideas?
Old Jul 23, 2011 | 09:11 PM
xRoguex's Avatar
bump for more ideas? new cam/crank sensors going in
Old Aug 7, 2011 | 07:59 PM
xRoguex's Avatar
Ok - so im convinced that in the 6 weeks that ID had my injectors.. they didnt actually do **** with them.
Because I for ****s n giggles put a STOCK set in... with the resistor box plugged in.
Car runs fine.
****in ID junk and tech.... FIC's are on their way. If they go in and work fine.. im going to send the ID's back and demand a refund.
Raceghost
Jun 10, 2016 11:28 PM
spdracr83
Jul 4, 2015 11:06 PM
han74j
Sep 23, 2014 03:37 PM
quinn6051
Oct 24, 2009 01:41 PM
batmoEVO
11
Jan 28, 2008 05:31 PM
