my compression test, thoughts/opinions?
Old Jul 11, 2011 | 08:49 PM
ProPilot04's Avatar
Sorry to be the new guy here... but can we be clear on this? Because now I'm confused...
I'm not certain that it would or wouldn't affect the data you're receiving, but I do believe that the spark plugs are supposed to be out of all four cylinders (dont forget to label lol)...
Old Jul 11, 2011 | 08:51 PM
Evoryder's Avatar
Typically you take them all out. The result doesn't change, the compression test is per cylinder.
Did the OP add a small drop of oil to the 2nd cylinder after getting the low results? If so did the numbers increase?
Old Jul 11, 2011 | 10:05 PM
italianevo88's Avatar
Let me just get my flame suit on...
But either way isnt it still a problem that 1 cylinder is significantly lower even though I did the test like a jackass
Old Jul 12, 2011 | 06:19 AM
Evoryder's Avatar
Re-test dry. Cylinder that is off from rest add drop of oil, test again. If the numbers are higher then you have cylinder ring issues and may need a rebuild.
Have a shop do a leak down for you and take it from there.
Old Jul 12, 2011 | 06:41 AM
Evoryder's Avatar
http://evoempire.org/topic/319-how-to-compression-test/
This is what the manual shows
Old Jul 18, 2011 | 08:07 AM
Evosick2332's Avatar
Vince make sure the car is completly warmed up and take out all the spark plugs. U said you let it crank 5 times. I normally go to around 7-8. I have a new compression gauge so if you want to try it again let me know
nukleus
18
Jan 8, 2016 04:05 PM
MrHouse
Jun 10, 2014 10:56 AM
EVOEvolved
21
Mar 16, 2013 08:04 AM
Supraboy1
North Texas Evo Club (NTEC)
18
May 31, 2012 03:46 PM
snafufx
Jul 6, 2011 11:07 PM
