Help..Blinking CEL under boost!?
Old Jul 18, 2011 | 10:12 AM
DSM1320Josh's Avatar
Hello how's it going I'm fairly new to my Evo it has basic bolt ons. Under boost the CEL blinks steadily then goes away then if I shift and boost again it comes back some times it blinks faster then others...I was wondering if this has happened to any other Evo owner out there! Thanks for looking and thank you for your help!
Old Jul 18, 2011 | 10:15 AM
mdsevo06's Avatar
That's probably Knock Count in your Tune. You should have the map looked at by a reputable tuner.
Old Jul 18, 2011 | 10:26 AM
Montu's Avatar
Tuners use your CEL as a knock counter. take it back to get the tune looked at
Old Jul 18, 2011 | 10:29 AM
Ok thanks guys.
Old Jul 18, 2011 | 12:02 PM
Previous tuner says he didn't set it up to blink during knock..any other sugggestions? Misfiring?
Old Jul 18, 2011 | 12:05 PM
evo8426's Avatar
If it blinks slow sometimes and fast sometimes its definitely the knock CEL flash being set.
gsrboi80's Avatar
Knock Cell is def set up maybe the tuner before him did it
Old Jul 18, 2011 | 12:19 PM
06MREvo's Avatar
Who is the "tuner"? Know anyone near you with ECUFlash & a tactrix cable you can use to check it?? I agree with what everyone else said...
Old Jul 18, 2011 | 01:44 PM
Local shop. And no I don't I'm going to ask around. Car is staying parked until it's figured out. Thanks for the feedback it's highly appreciated.
Old Jul 18, 2011 | 03:06 PM
gsrboi80's Avatar
Figure out what?? Not ask who?? We are telling you what is going on. Rom is modded so that the CEL will blink with knock sum
There are parameters to set
Over a certain RPM
Over a certain Load
X amount of knock counts for slow blink
X amount of knock counts for fast blink
Old Jul 18, 2011 | 03:50 PM
Figure who has a cable and ECUflash who is familiar with it becaue I am not. I know you all are telling me what is going on and I appreciate it. But I personally can't do anything because for one I don't have a cable and two I'm not familiar with the program and probably would make matters worse. Thanks for your input.
Over a certain RPM
Over a certain Load
Old Jul 18, 2011 | 03:57 PM
getsideways's Avatar
Did you have the car retuned?
Old Jul 18, 2011 | 04:09 PM
When I purchased the car yes.
Old Jul 18, 2011 | 07:12 PM
barneyb's Avatar
From the factory the SES does not flash. For it to flash someone has to program it to do so.
The engine has a knock sensor. When the sensor tells the ECU that knock is occurring the ECU will reduce timing and boost to protect the engine. Reducing timing and boost also reduces horse power.
A good tuner will endeavor to reduce knock as much as possible in order to allow the engine to make as much horse power as possible. It is also a common tuner practice to program the SES light to flash when knock is occurring. This to tell the owner that knock is occurring.
Old Jul 19, 2011 | 06:47 AM
Montu's Avatar
does this tuner actually have good experience with evo's? are you sure he didn't just download some roms and tweak them for your car and thus would have no idea the SES flash was set up for knock?
Just checking.
Dremoco
Jan 5, 2015 04:56 PM
AlisterMcRae
23
Jun 26, 2012 06:23 AM
degin219
May 7, 2011 04:44 PM
jjayp
Mar 12, 2011 12:01 AM
DragTheater
12
Dec 17, 2009 10:20 PM
