In a jam here
Old Jul 20, 2011 | 05:05 PM
impact blue's Avatar
In a jam here
Okay I seem to have one last problem with the evo 9. Okay now when I turn the sterring-wheel all the way to the left or all the way to the right and try to move forward it kind of studders a bit like something is holding it?
What do I do what should I look for? I have stock wheels on btw not sure if its fender rub and my car isnt not lowered at all. What gives?
Old Jul 20, 2011 | 06:00 PM
KWezzy's Avatar
power steering pump possibly.. I think every car I have driven if you turn the wheel all the way studders alittle bit even a brand new car!
Old Jul 20, 2011 | 09:17 PM
hmm car does sound funny when I start it up though too sounds like a siezed belt not a squeeky one is the car supposed to sound like that?
Old Jul 20, 2011 | 09:34 PM
Tuxevo's Avatar
That's the car saying, 'please don't crank the wheel all the way over and hold it against the lock, it hurts my cv joints. Let off just a bit, you won't notice a difference.'
Old Jul 20, 2011 | 10:05 PM
Evo_Jr's Avatar
This. I've notice that noise more in bigger vehicles.
Old Jul 20, 2011 | 10:17 PM
Its not in the lock position at all. When the wheel is straight no problem when the wheel is turned either to the left or to the right not al the way the car jumps not the steeringwheel either. Its like something is holding onto the car I looked inside the wheelwell no marks of the tires rubbing ?
Old Jul 20, 2011 | 11:39 PM
barneyb's Avatar
Probably the clutches in the rear diff.
Old Jul 20, 2011 | 11:42 PM
justinduh's Avatar
check your front axles they are probably binding and might need replaced...
check for cut boots/leaking grease
how many miles are on the car?
Old Jul 21, 2011 | 01:13 AM
26k
Old Jul 21, 2011 | 01:14 AM
it only happens when i turn the wheel only though.
Old Jul 21, 2011 | 01:19 AM
Chadwick4477's Avatar
My Diesel does this quite a bit and especially if I have a payload in the bed
Old Jul 21, 2011 | 08:26 AM
barneyb's Avatar
The rear differential has a clutch type locking mechanism and smooth operation requires the correct lubricant or some friction modifier additive. The easiest way to assure smooth operation is to use diaqueen.
Lombardi23
For Sale - Wheels / Tires
Jul 1, 2016 09:04 PM
716amg55
Sep 26, 2011 12:01 AM
impact blue
Aug 4, 2011 11:47 PM
TaiwanEvo
Mar 1, 2008 07:32 AM
projekt_shocker
Feb 21, 2006 09:54 AM
