transmission hard or can't shift in gear. please help!
Old Jul 25, 2011 | 11:23 AM
pkboy's Avatar
hi guys i have a evo8 5speed that had the exeddy twin disc clutch installed from the last owner, now i replaced the engine and putted everyting back the transmission is hard or can't get in to the gears. does any one here with this kind of experiences. i don't know if i used the wrong oil in the tanny, i putted 75w-90 in it, but should make a big different. so thank you if anyone can give some idea. or did i had some wrong installation.
Old Jul 25, 2011 | 11:32 AM
newimportowner's Avatar
You may want to check the alignment of the shifter under the hood. the thing with the big counterweight on it. the holes are quite a bit bigeger than the bolts that hold it down. you usually can get it in some gears though if its not aligned properly.
Old Jul 26, 2011 | 08:33 PM
pkboy's Avatar
can't tell what is wrong with the exedy twin plate clutch, but it is gonna be it, i felt the clutch can't fully disengage.
Old Aug 24, 2011 | 06:13 AM
VrMPSHHH's Avatar
U figure it out? I'm having the same issue
eddy5201314
Nov 4, 2016 02:14 PM
mklepper
Aug 17, 2016 04:33 PM
fireroasted
13
Jan 13, 2016 04:35 PM
DynoFlash
31
Dec 18, 2010 11:21 AM
SuperHatch
19
Apr 20, 2006 10:52 PM
