Evo 8 check engine light & problems
Old Aug 8, 2011 | 10:13 PM
Revo15's Avatar
2003 evo 8
Mods: Greddy full exhaust, Aem intake, forge dv.
Problem: the car only boosts at 15 psi and feels like its getting some serious boost cuts but cant find any leaks my check engine light is on and here are the following codes: p0137, p0139, p0401, p0137 pd, p0401 pd.
I tried looking for boost leaks and cleaning the egr valve and cant find anything..problem still not solved
Can someone please help me???
Old Aug 8, 2011 | 10:18 PM
06RedRalli's Avatar
Have you recently changed anything that could cause these codes to pop up?
I.e. put on a test pipe?
The sensor codes tell us that the two o2 sensors are not getting the correct
feedback between each other...easiest fix is to disable the second o2 sensor
via ecuflash...
And the egr codes that you've shown most commonly show up when one of
the hoses has come off the egr valve...you sure all are connected?
Old Aug 8, 2011 | 10:23 PM
Revo15's Avatar
No i didnt do anything to it still stock cat and i checked all the egr hoses..still plugged into the egr.
Old Aug 8, 2011 | 10:29 PM
06RedRalli's Avatar
Do you have a wideband? Could be a faulty or dieing front o2 sensor or even rear o2?
Old Aug 8, 2011 | 10:33 PM
EVO Nate's Avatar
make sure your fuel regulator valve is still secured, crazier things have happened
Old Aug 8, 2011 | 10:39 PM
06RedRalli's Avatar
^True..maybe the hose popped off the fpr.
Old Aug 8, 2011 | 10:42 PM
Revo15's Avatar
No wideband..just oem o2 sensors so the egr and the fpr could possibly set off all these codes?
Old Aug 9, 2011 | 12:25 AM
06RedRalli's Avatar
Those are just two things that can be checked first...as they are easiest to check.
Old Aug 9, 2011 | 02:00 AM
Revo15's Avatar
Ok i will check them..
mdknutsen
Jun 11, 2016 03:58 PM
Liquid0401
37
Sep 5, 2011 10:01 PM
meat_EVO
Feb 11, 2009 12:28 PM
BluesunsXIV
Nov 26, 2008 09:33 PM
P0411
Mar 2, 2006 08:25 PM
