oil dipstick pop up and crank oil leak
Old Aug 15, 2011 | 01:29 PM
crisdiarata's Avatar
Originally Posted by BoostINurI
Had same issue kinda....what i did to fix was double up rear pcv valve ( one way check valve) along with oem pcv. I aslo deleted catch can on driver side valve cover breather and ran strait to turbo intake tube. This was all after opening up fittings on valve cover from stock up to 3/8 barb fittings. This fixed my smoking fp black problem....and no i dont have oil coated ic pipes.
Hope this helps man....if all else fails i would check compression and leakdown....rings may just be super pissed off and need a rebuild.
Good Luck bro!
Where did you connect the double line coming from the pcv valve?
having the driver side valve cover breather and ran strait to turbo intake tube won't get you smoke?
Titish
18
Sep 6, 2014 09:02 PM
bigben
33
Nov 3, 2013 04:46 PM
AJsGenerX
16
Sep 8, 2012 06:43 PM
strtrcng426
Sep 20, 2010 02:12 PM
David Buschur
68
Jan 24, 2008 11:13 PM
