Evo IX 2-Step doesnt work
Old Aug 30, 2011 | 06:19 PM
1d10t's Avatar
Car must be warmed up. Does throttle need to be 100%?
X2 on clutch switch
Old Aug 30, 2011 | 09:27 PM
Anubis18's Avatar
I noticed this with my 04 evo. Mines doing the same thing. I had my friend pull it up on his computer and it was set to like 6200 or something ridiculous, so we dropped it down to 5k. I went home and tried it and it went right past 5k to like 6k. I didn't let it get any further.
Old Aug 31, 2011 | 09:16 AM
evo8426's Avatar
Originally Posted by EVOSE06
If you are talking about the factory 5,500 RPM limit that Mitsubishi gives the car to protect the drive train from abuse, I'm pretty sure that's easily disabled. So unless you bought the car new, the previous owner probably had it turned off.
Factory is set at 5,000.
I would make sure the clutch switch didn't break or come unplugged. You can look up under the dash to find it.
Old Aug 31, 2011 | 10:54 AM
Anubis18's Avatar
Anyone got a how-to for Showing Where this switch is and to see if it's workin or not? Haha
Old Aug 31, 2011 | 11:00 AM
evo 9 guy's Avatar
It is the only switch that your clutch pedal will hit when fully depressed.
Old Aug 31, 2011 | 12:54 PM
blackenedwings's Avatar
X2 on clutch switch
No, the throttle does not need to be 100%... don't do that. Slowly/smoothly bring revs up to 5500 rpms, if the car is not moving (flat/level) and clutch is fully depressed you will catch at the 2-step limit.
Old Aug 31, 2011 | 12:56 PM
SavEVOIX's Avatar
Originally Posted by blackenedwings
That is not true. If you have the e-brake on you can actually use it to hold the car perfectly still to ensure 2-step is working correctly. Push the clutch in, put the car into 1st, pull the e-brake up, then ease the rpms up to 5500.
This is how I stage up @6000 without slightly rolling over...although I usually floor it rather than "ease up"
ApexLate
Jan 13, 2015 11:35 PM
ApexEVoIX03
Apr 9, 2014 04:32 AM
Silver-IXse
Apr 1, 2014 04:58 PM
audiofan
Apr 3, 2011 05:36 PM
